Valve Tick Normal?
Old Sep 9, 2007 | 06:53 PM
KS_Evo9's Avatar
Valve Tick Normal?
Is valve tick normal for stock evos? The reason I ask is cause I noticed my motor has always been kinda ticky so was my previous evo 8. Both these cars were bought off the showroom. So is this normal?
Old Sep 9, 2007 | 06:55 PM
EvoJoeIX's Avatar
its not the valves....
its the injectors
Old Sep 9, 2007 | 06:58 PM
KS_Evo9's Avatar
OIC so is it normal? Im also using RP motor oil does this have anything to do with the TICKynesS. M1 FTW????
Old Sep 9, 2007 | 07:02 PM
EvoJoeIX's Avatar
dude motor oil has nothing to do with injectors...
yes its normal
Old Sep 9, 2007 | 07:11 PM
KS_Evo9's Avatar
I heard some1 say after they switched to RP they had valve tick so I was worried. I know that motor oil has nothing to do with injectors. WOW
Old Sep 9, 2007 | 07:12 PM
jrsimon27's Avatar
what weight of oil do you have?
Old Sep 9, 2007 | 07:13 PM
KS_Evo9's Avatar
10w30
Old Sep 9, 2007 | 07:22 PM
jrsimon27's Avatar
Originally Posted by KS_Evo9
10w30
the ticking your hearing must be from the injectors i doubt that your lifters are bad/
what mileage does the car have?
Old Sep 9, 2007 | 07:31 PM
KS_Evo9's Avatar
almos 7k
Old Sep 9, 2007 | 07:34 PM
ALLBLACK-EVO's Avatar
It is common on all 4G63 motors. Been common since the first evo which was called the VR4 RS. Changing to a good oil should help get rid of it temporarily, but it will come back again. It is not in the injectors either, just the sticky lifters.
Old Sep 9, 2007 | 08:11 PM
BluEVOIX's Avatar
You could try putting your fingers on the injectors and feeling the pulse. If it is in sync with the ticking noise then most likely its the injectors firing noise.
Old Sep 9, 2007 | 08:18 PM
jamerin's Avatar
mine only comes on when the a/c on
Old Sep 9, 2007 | 08:20 PM
Tsurugi-san's Avatar
JAM no-tick lifters --- they help alot.
Old Sep 9, 2007 | 08:21 PM
Hah! I just evolved! Doin' the dance . . . feelin' the flow . . . all good things
Old Sep 10, 2007 | 02:39 PM
EvoJoeIX's Avatar
put your finger on the injector and you will feel the pulse...
on motor with 7k on it, there is a slim chance its accually valve tick. the injectors will sound just like a valve tick. 4g63 injectors have always been quite loud
