Greddy Ti-C Silencer Removal
Old Dec 17, 2007 | 08:29 AM
  #31
Sluggo's Avatar
Originally Posted by WICKed'N'EVO
here's How to removal
ur silencer was still attached to the ti tip when you unscrewed it? you got lucky then, mine is stuck inside the muffler and i have no leverage on it.
Old Dec 17, 2007 | 02:37 PM
  #32
Sluggo's Avatar
i'm getting owned by this thing, wd40 + coat hangers didnt budge. how exactly do you use a slide hammer?
Old May 19, 2008 | 03:15 PM
  #33
Speed Element's Avatar
There's a better way of removing the silencer without remove the bolts of the exhaust tip.
All you need is to unscrew the silencer bolt (1 bolt), and find a long metal rod that has a hook or something in similar fashion, stick it in until it hooks up the edge of the silencer opening and yank that **** out as hard as you can. VIOLA
our home made silencer removing tool - a rod w/ two bolts screwed on both ends.
Old May 19, 2008 | 05:03 PM
  #34
PHDoc19's Avatar
Go to Autozone (or any auto parts store), buy some PB Blaster for about $5. It is the best commercial penetrating oil known to man. Spray the entire rim of the exhaust where the silencer is. Let it sit an hour. Go outside and spray it again. Let it sit an hour. Pull it out with easy. No fuss, no mess. This stuff also works well for studs and most other bolts. Good luck.
Old May 19, 2008 | 05:36 PM
  #35
lancerMRguy's Avatar
slidehammered that **** out it was stuck.
Old May 26, 2008 | 03:56 PM
  #36
MR.Evo.06's Avatar
Used a pressure washer spray gun (quick connect). Put the quick connect end into the silencer caught the edge then pulled. No damage to the silencer and came out in one yank.
Old Jun 20, 2008 | 03:40 PM
  #37
teamsprock's Avatar
I know this is a pain in the a$$ to get out and lots of people damage them, so I have one that I got out with only one slight ding, so if anyone wants one I will sell it for cheap, just PM me about it.
Old Nov 21, 2008 | 06:39 AM
  #38
DMobMichael's Avatar
what does the silencer look like? I have a Greddy Ti-C and i can't seem to Figure out what part the silencer is. Do some of them not come with one?
Old Nov 21, 2008 | 11:07 AM
  #39
Phillip04Lancer's Avatar
Quick question about the silencer. I took mine out today. Is it okay to leave just the tip on, you know, without the screws. Will if fall off?
Old Nov 21, 2008 | 02:41 PM
  #40
oneofakindtrini's Avatar
i hate how the silencer looks!
Old Nov 23, 2008 | 12:59 PM
  #41
Chukee_R's Avatar
You need to bolt the tip back on. If it's just sitting there it will definitely just fall off.
Old Nov 23, 2008 | 03:50 PM
  #42
Do I use the original bolts, cause they don't go in without the silencer at all?
Old Nov 23, 2008 | 04:37 PM
  #43
Oh, I figured it out. I went to the store and purchased some aftermarket locking nuts (like the ones welded onto the silencer) while still retaining the original bolts. It looks like it will stay on now thanks. I would have driven on the freeway and lost such a nice tip lol. Thanks whoever posted before me!!!
Old Dec 24, 2008 | 02:22 PM
  #44
Jimmy Javelin's Avatar
I just got it out today. No joke, use PB blaster. Like $3 at autozone. Pretty easy. Sounds great
Old Dec 24, 2008 | 07:10 PM
  #45
Turbodemon's Avatar
i used a pair of needlenose pliers and a flathead a very small one.
just kept working one side at at time untill i got to pull the dam thing.
a real pita
