Transmission FLuid Help
Old Sep 18, 2007 | 03:49 AM
acid668's Avatar
Exclamation Transmission FLuid Help
Hi.. My Evo 9 just arrived from Japan. Was wondering if i should change the transmission fluid for my car? If i need to does anyone have any good recommendation. COS i wouldnt wanna F**K Up my drivetrain.. PLS HELP
Old Sep 18, 2007 | 03:57 AM
cetinsaya's Avatar
also I wouldnt wanna F**K up my tranny! oem fluids are makes me sick! since I bought the car my tranny problem never been end !!!
I'thinking to buy BG tranny oil but someone said BG1 someone said BG2... I couldnt make my choice... which one is true!? help !?
Old Sep 18, 2007 | 04:45 AM
Smike's Avatar
NEITHER BGI or II. That fluid sucked - broke down and expanded in under 5k.
First off, if the car is new - why change the fluid out of the gate? Run it, break it in, then change the fluid when the manual states (if just daily driving - racing is a different story).
Secondly, what trans 5sp or 6sp? If 6sp, use the Mitsu Diaqueen for the 6sp.
There are some huge threads about this (here is one):
https://www.evolutionm.net/forums/sh...d.php?t=248365
I run Amsoil trans fluid now - much better than BG. Others I know run Redline.
Old Sep 18, 2007 | 05:01 AM
acid668's Avatar
Sorry for the lack of information.. My EVO 9 is six speed and it is a used car from japan which has 26K mileage on it... Thats y i am wondering whether there is the need to change tranny fluid and which kind. Cos i see there is a lot of debating going on.
Old Sep 18, 2007 | 08:49 AM
phenaly's Avatar
Use the 6spd Diaqueen for the 5 AND 6 speed transmissions!
26k used, I would swap the fluids out....don't forget the transfer case as well.
Old Sep 18, 2007 | 02:11 PM
cetinsaya's Avatar
diaqueen is most known fluid ... I heard that name so much...
Old Sep 19, 2007 | 05:16 AM
acid668's Avatar
Really appreciate the info i am getting.. Ill do with Mitsu Diaqueen Cheers all the way.. !!
Old Sep 19, 2007 | 08:35 AM
tiffany&coNY's Avatar
I bought my evo used as well and had all the fluids flushed out and changed. my bf started a thread about basically the same thing. this may not be AS helpful as the link SmikeEvo provided, but hopefully it's some help.
https://www.evolutionm.net/forums/sh...d.php?t=291083
Old Sep 19, 2007 | 09:03 AM
ttbestas's Avatar
use redline oil
Old Sep 19, 2007 | 09:07 AM
evo1337's Avatar
in an 8 use diaqueen in the transfer case and diffs and redline mt-90 in the trans.
Dont know if its different for the nine. But I searched forever before buying. Also GL at finding diaqueen locally
Old Sep 19, 2007 | 09:10 AM
Redline-Z's Avatar
Veteran: Air Force
Redline MT-90!
Old Sep 19, 2007 | 09:15 AM
tvbf1's Avatar
I just changed my Tranny fluid with the Mitsu MT tranny fluid. Feels alittle smoother, but the thing cost over $80 for a gallon jug.
Old Sep 20, 2007 | 03:40 AM
acid668's Avatar
Thanks for all your recommendations. Seems like i will have quite a few to think about here... Appreciate it guys.
