question about t-case fluids.
Old Sep 20, 2007 | 04:54 AM
daechul2da's Avatar
I have a bad T-case and it was whining real bad. So i bought a used T-case to install and while i was watching the installation i noticed that T-case oil is very thick and when my blown T-case was being drained it wasn't thick at all. And this got me thinking i had a clutch install from the dealer once and could they have put the wrong fluids in during the clutch install? Or does a blown T-case cause the oil in T-case to go very watery?... And if it was wrong fluids during installation from dealer.. is there a way i can check which oil they used? is there a record they keep on which oil they used? .... I seem to be rambling on with questions but this isn't very cheap to replace and wanted to know if it was the dealers fault.
please help...
Old Sep 20, 2007 | 05:12 AM
gsrboi80's Avatar
The OEM Diaqueen LSD Gear Lube that needs to be used in the Transfer Case is very thick. You should not have a thin fluid in there.
Old Sep 20, 2007 | 05:16 AM
daechul2da's Avatar
yes.. I have seen that oem diaqueen LSD gear lube and when i drained the T-case it wasn't even close to being thick..so my question still remains .. Is there a way to check with the dealer on which oil they used? do they keep a record on which oil they used for which application?
Old Sep 20, 2007 | 05:18 AM
rcheung's Avatar
The best thing would be to call them up and ask them what oil they use for the tcase.
Old Sep 20, 2007 | 05:24 AM
fbomb's Avatar
Yes and no -- some dealers will bill the oil on the repair order...If diaqueen was in stalled it would have been billed...check your bill...
Old Sep 20, 2007 | 05:28 AM
daechul2da's Avatar
so my best bet is to go to dealer and check it out by myself.. huh..
Old Sep 20, 2007 | 05:32 AM
fbomb's Avatar
do you have bill
Old Sep 20, 2007 | 05:38 AM
daechul2da's Avatar
i lost the clutch install bill so do i have no proof even if they did put the wrong fluids in?
Old Sep 20, 2007 | 05:42 AM
fbomb's Avatar
ask them to reprint you a bill...they have to have the record for 7 years...
fbomb's Avatar
Do not tell them why,just that you lost it and need a copy...
Old Sep 20, 2007 | 05:48 AM
Dont Try To Run's Avatar
Yeah just ask them for a copy first, then try to get the free tcase... good luck though.
Old Sep 20, 2007 | 06:00 AM
daechul2da's Avatar
i can get a t-case from them if i found out that the oil they used is the wrong oil right? But even if they didnt use the oil and if it says they used oem diaqueen lsd lube.. can i take the fluid i took out from the t-case to examin it or something cuz it sure aint thick as it should be.
Old Sep 20, 2007 | 06:12 AM
I honestly would get the paperwork first. See if they used the right oil... If they used some knock of brand or maybe even a different fluid for the Tcase during your clutch install (did you tell them to change the tcase fluid too?). Then talk to the manager... Your Tcase is whining really bad... Are you stock or modded?
Old Sep 20, 2007 | 06:17 AM
daechul2da's Avatar
i'm modded but only exhaust and MBC.. so i guess i ll just check how this goes..
and hope they used the wrong lube and get a t-case out of em
Old Sep 20, 2007 | 07:51 AM
bolvangar's Avatar
that stuff was like water man!
