Vibrations
Old Sep 25, 2007 | 01:02 PM
J-ROC's Avatar
Vibrations
this is weird... My car vibrates at high rpm and highboost. it doesn't vibrate when i'm driving normal or at a lower boost.(15psi) but when i get it at WOT, with 23psi the front end starts to vibrate... I assumed it was my tires, so i went out a purchsed a new set, but issue still occurs. does anyone know why this is happening..
Old Sep 25, 2007 | 03:34 PM
TunerHead24's Avatar
how fast are u going when it happens?? does the steering wheel start to shimmy??
Old Sep 25, 2007 | 05:19 PM
chaz517's Avatar
my wheel shimeys at 75 but not 65 and is annoying, maybe an alignment or rotations is needed? doesnt do it until 75 mph
Old Sep 25, 2007 | 05:58 PM
J-ROC's Avatar
well it happens when i'm gunning it at high rpms, and high boost. i can be at a dead stop, and take off at WOT, then it will start vibrating like around 5k rpm's with high boost. the steering wheel shimmy's only when i gun it. but when driving normal, low rpm, and no boost its fine. Even when i'm going like 100mph it doesn't vibrate, it only vibrate when i'm at peak boost, and high rpms... it weird. i went and got my wheels checked today, and nothing was wrong with them. I even tried getting the wheels road force balanced with the hunter machine.... I'm running out of options of what to do... any idea what is the cause of this????
Old Sep 26, 2007 | 05:27 PM
i think your balancer shaft must be off, that can give you vibrationd at high rpm! did u install cams??
Old Sep 26, 2007 | 05:37 PM
Redline-Z's Avatar
Veteran: Air Force
If this is the case get it fixed yesterday!
Old Sep 26, 2007 | 06:11 PM
CarbonKrazyEvo9's Avatar
^---------I agree
