VDO Turbo Boost Guage
Old Sep 27, 2007 | 10:48 AM
jonjon123's Avatar
I have a VDO turbo boost gauge installed in my car which was done by previous owner. The gauge reads both (in Hg) and (PSI). When I start the car it goes to 20 in Hg at idle. Is this correct? When I get on the throttle the needle goes past the 0and goes into the PSI area of the gauge. If someone can explain this I would appreciate it. Im not sure the gauge is hooked up right. I have already fixed the oil pressure gauge which was wired incorrectly that is why I am questioning this gauge. I never dealt with a turbo before. thanks for any help could not find any infor at VDO site.
Old Sep 27, 2007 | 11:12 AM
TouringBubble's Avatar
Yes, the gauge is functioning properly. At idle you will be in vacuum (below 0). you will also be in vacuum at a light throttle cruise and in heavy vacuum if you are in coasting down in gear. You will only see boost on the gauge when you are accelerating.
