problem tranny, synchro
Old Oct 7, 2007 | 06:40 AM
Malik_EvoIX's Avatar
Question problem tranny, synchro
hi, i own a new evo ix with light mods and when i shift to 3rd or even downshift it grinds it is stock clutch. i know it is the synchro even by researching bout it, so i took it to the dealership and they told me it is the "pressure plate" iam like WTF can anyone help me out?!!
Old Oct 7, 2007 | 07:31 AM
gsrboi80's Avatar
Syncro is shot man. Have Shep or TRE rebuild it for you cost you about 1200 or so
Slo_crx1's Avatar
Have you adjusted the clutch pedal at all? My 8 liked to stick in between gears, especially after you drove it for a little bit...a pedal adjustment took care of that issue. If the clutch doesn't disengage all the way it probably will grind.
Old Oct 7, 2007 | 07:40 AM
the dealership said get a clutch aftermarket or not since anyways i need a clutch and if it still grinds, they will fix it, they told me they checked the synchro and it looks fine but the pressure plate doesnt.
