Help Help Help!!!!
Help Help Help!!!!
Well, I was install my gauges tonight, and my Dad thought that the bolt on the passenger side of the front swaybar would be a good ground for the oil gauges! This is the bar with 3 bolts! Well he didnt spray the bolt with anything, just tried to take it out, and what do ya know, snap! He broke the head off the bolt! Then he decides he will use his screw-out and try to take it out, well he drills on the side of the bolt and it goes up between the bolt and the threads, and messed up the threads! Now I have the bolt still flush in the mount and a hole through the trheads!
Im trying to figure out where to take it in order to get the rest of the bolt out, and get it re-tapped to put a new bolt into the sway bar!
Thank You for all your help!
