Fuel Pressure Adaptor
Ok, so I have my fuel pressure gauge installed, and I finally got my Fuel Rail Adaptor from UR to install the sender. So my question is, where does the adaptor hook onto the fuel rail? it has 2 bolts that connect it onto the rail. So does anyone have any pics of one installed? Thanks!
As long as you are checking the fuel pressure between the fuel pump and the fuel pressure regulator you are fine. I installed mine on the drivers side of the fuel rail. I disconnected the feed line going into the rail and it sandwiches between the feed line and the rail.
