a Different opinion needed
Old Oct 17, 2007 | 08:41 PM
SpeedJunkyz's Avatar
I am under the impression that I blew my head gasket, I had posted awhile ago about it. I havent gotten around to fixing it yet. I have been really busy with work and customers. However I was pulling the LICP to check something(just tinkering) and I would say about 1/4 to 1/2 cup of motor oil poored out of the pipe. Is this normal of the head gasket blowing? Or shall I add another thing to fix on the car? Here is the oil puddles, I placed familiar garage tools to giv eyou an Idea of the size.
SJ
Old Oct 17, 2007 | 08:48 PM
evo_knight's Avatar
that's a new one to me...get a catch can maybe...or your car is on the rag...
Old Oct 17, 2007 | 08:49 PM
bigric09's Avatar
maybe the catch can, or a seal in the turbo is blown as well.... on second thought, id say there is no way that is blow by... way too much oil, unless your car is 5 yrs old
Old Oct 17, 2007 | 08:56 PM
evo_knight's Avatar
Originally Posted by bigric09
... seal in the turbo is blown as well.... on second thought, id say there is no way that is blow by... way too much oil, unless your car is 5 yrs old
yeah i agree, if the turbo is bleeding
Old Oct 17, 2007 | 09:22 PM
I have a can, I do have a 2003 so almost 5 years old LOL, and can i find tampons for turbos?
So maybe it is the seals ARGH!!!
SJ
Old Oct 18, 2007 | 10:53 AM
LoCo4's Avatar
SJ
Just get a new turbo!
Old Oct 18, 2007 | 11:03 AM
JrCRXHF's Avatar
turbo rebuild time.
Old Oct 18, 2007 | 01:14 PM
goBYeBYe's Avatar
yeah thats a sign of bad turbo seal. Time to upgrade.
Old Oct 18, 2007 | 01:17 PM
shivaswrath's Avatar
if it's coming outta the LICP, I'm leaning towards a turbo related problem. . .I see a Fp Green in your future!! not a HG problem, but internet diagnosing is retarded most of the time. . .g-luck!
Old Oct 18, 2007 | 01:24 PM
05blue8's Avatar
Any oil/coolant mixing? I didn't see the original thread so what led you to believe it was a blown HG?
Old Oct 18, 2007 | 10:53 PM
^ well I had just got down wrapping the header, DP, and some other engine parts, changed the oil pan gasket, along with turbo oil feed gasket. I button everything back up, checked over work. I then like I always do drive around the block to insure I did everything right. Well after about 5 minutes of driving, extreme amounts of white smoke starts to poor out of the exhaust and engine area. I also got a very loud(supercharger like) sound coming from under the engine. This was at first start up, it went away after pushing the clutch in, so I didn't think anything of it. I prolly fudged something with that. Very loud whining. I pulled into the drive way to stop and got out to look at what was going on. I shut it off and let it clear out. I saw nothing standing out, I then tried to start it and pull it back into the garage and it wouldn't move without a lot of rpm's. Very sluggish, wanting to shut off. I pulled the DP and poored a CRAP load(half quart) of oil out of it. Didn't think to pull the LICP. I had alittle oil pan leak, since I had just replaced the gasket( I apparently didn't secure it right HAHA!) and I checked the oil, noticed I lost a lot of oil. I talked with CBRD and they said its a high possibilty its my HG. I would like someone to tell me its something cheaper to fix HAHA.
Resealing the turbo, can it be done by me? Is there a "How to" tear down a turbo? I have a turbo place around my area, but they said clipping and porting my setup would only give me more lag and higher topend. Sorry for the long reply.
Old Oct 18, 2007 | 10:54 PM
Oh and no coolant mixing in the oil I poored out of the DP nor the LICP
Old Oct 19, 2007 | 02:39 AM
krazirob's Avatar
just switch it out for a BR 20G......you might even be able to just turn yours in and they will rebuild it for you.....just a though
Old Oct 19, 2007 | 04:36 AM
Cinci Turbo IX's Avatar
puddles of oil like that are never good if your not doing an oil change.. has to be seals though.. A head gasket should not let oil pass like that unless you blow oil rings.. and then it should not come back through the intake it would go through the exhaust.
Old Oct 19, 2007 | 03:21 PM
CBRD's Avatar
i dont remember talking to anyone about this?!?!?!
cb
