Help Installing HALLMAN EVO RX MBC KIT
Old Oct 19, 2007 | 03:37 PM
KS_Evo9's Avatar
Ok guys so my MBC just came in. I was looking for a way to run the hose through the firewall for the cockpit controller and couldnt find a place. So me and a friend came to the conclusion that we would have to drill one ourselves. I was thinkin maybe where the throttle body cable goes through the firewall. Any help would be appriciated or info on how you did yours/ran your cable. Thanks
Old Oct 19, 2007 | 04:03 PM
garcias2k's Avatar
I drilled mine next to the brake booster. I will post some picks for you. But, where you drill will depend on where you place the boost knob.
Old Oct 19, 2007 | 04:07 PM
SiCKlEyWiKeD's Avatar
if you don't mind running a long hose, there's a rubber grommit on the passenger side just behind the box that you can run it thru. Just push the grommit out.
Old Oct 19, 2007 | 04:17 PM
bboy_RES's Avatar
i'm planning on getting the same boost controller and i was gonna route the hose the same place i routed the power cable for my amp. behind the driver side headlight and through the rubber grommet by the wheel well.
Old Oct 19, 2007 | 04:22 PM
garcias2k's Avatar
Unfortunately, the hose kit that adjusts the boost controller can only take slight curve-bends otherwise it won't turn.
Old Oct 19, 2007 | 04:34 PM
garcias2k's Avatar
Here are some pics of my install.
Attached Thumbnails Help Installing HALLMAN EVO RX MBC KIT-picture-001.jpg   Help Installing HALLMAN EVO RX MBC KIT-picture-004.jpg   Help Installing HALLMAN EVO RX MBC KIT-picture-002.jpg   Help Installing HALLMAN EVO RX MBC KIT-picture-006.jpg
