Headlight question
Old Oct 21, 2007 | 01:45 PM
nikkadanny's Avatar
Headlight question
i just got my hid conversion kit and i need to find out where to put the - and +, cause i unplugged the bulb and theres a clip with 2 black wires, one is solid black and the other is black and has a white line down the middle which is positive and negative?
Old Oct 21, 2007 | 01:57 PM
glgz's Avatar
in most cases solid black would be your ground and the the black with white strip is the postive. To know for sure you could test with a multimeter if have one.
Old Oct 21, 2007 | 03:12 PM
holler mcdollar's Avatar
^yep. black should be the negative ground and black/white strip should be positive. search a bit first if you don't have a multimeter to test with.
