Problem with switching the car over to heat. Worked the other day, not anymore.
just called and here is what i have
4 part numbers
7801A360 - blend door kit = $64.00
7801A110 - blend link and lever kit - $12.97
MN185231 - blower motor filter - $45.47
MF453032 - bolts needed for the kit - 0.35 each
the blend door kit is out of stock everywhere so he said it might be backordered.
this is such BS that its not a Recall!!!!!!
4 part numbers
Damn! The last two 03 evos I've owned have the exact same problem! I have to put a glove on, then push or pull the white plastic gear for climate control...makes me wonder if my car is eally an 03 or an 83.
I was all through this last spring.
If you want the heat control knob to be silky smooth like on the new Evos then you need all the parts listed above. To install the blend door the heater box has to come out. Before the heater box can come out the dash must be removed. Removing the dash is a 1000 piece jigsaw puzzle. If you want the knob to stay silky smooth you need to install the cabin filter.
If you will settle for the knob working well enough that is won't break and much better than it does now then all you need are the blend link and lever kit. And, this can be installed without removing the dash. It is a DIY project.
