Took off the Kartboys, put stock bushings back on
Old Oct 28, 2007 | 02:12 PM
Chemwarrior's Avatar
I was having a lot of lockout when I would shift at a high rpm so I decided to see if it was the Kartboy shift linkage bushings. The car shifts A LOT better after putting the stock bushings back on. I didn't think it would make a lot of difference but I was wrong.
Old Oct 28, 2007 | 02:14 PM
JakeTheVIII's Avatar
Mine does this too, I might try that.
Old Oct 28, 2007 | 02:28 PM
chaotichoax's Avatar
Buschur bushings FTW
Old Oct 28, 2007 | 02:30 PM
Lancematic's Avatar
I have the zaklee and I love them
Old Oct 28, 2007 | 02:55 PM
I thought about going with Buschur's bushings, but I am a little apprehensive about going with metal bushings since they have a tendency of locking up in cold temperatures.
Old Oct 28, 2007 | 02:56 PM
CrackerJackToy's Avatar
If there lubed up enough, you wont have that problem.
Old Oct 28, 2007 | 02:59 PM
EvoJoeIX's Avatar
my friend gave me metal bushings, i think they might be buschur and im experiencing a lot of problems with high rpm lock-out and its real hard to get the car in reverse...
Old Oct 28, 2007 | 03:01 PM
Therein lies the rub; you have to constantly lube it.
Old Oct 28, 2007 | 03:15 PM
rsboy's Avatar
I had the kartboy shifter bushings for over 20K miles and no problems. Just clean them once in awhile and put enough grease on it.
Old Oct 28, 2007 | 03:17 PM
I was not aware that you had to grease the polyurethane bushings. That was one of the reasons why I bought them. It makes sense though because they were a pain in the *** to remove because they were stuck in there.
Old Oct 28, 2007 | 03:35 PM
I massively lubed my buschurs with Mobile 1 synthetic grease. I have no problem with any rpm lockout.
Old Oct 28, 2007 | 03:38 PM
my only lockout is occasionally in forth gear at high rpm but that is 100% because of my ACT clutch...because it happened with the stock bushing too
my car is "more" difficult to get into reverse but it's nothing crazy
question: how often should they be re-greased?
Old Oct 29, 2007 | 06:53 AM
evolved83's Avatar
i would like to know as well
Old Oct 29, 2007 | 07:43 AM
rsboy's Avatar
yeah... the plastic itself is fine but the metal it attaches to gets dirty and crap so the grease helps it from getting stuck. White lithium grease and/or anti-seize works very well, also.
Old Oct 29, 2007 | 10:54 AM
scheides's Avatar
EvoM Moderator
I have buschur's buschings, never had to lube them and never had them be sticky in the cold. Gets down to -40 here in MN and they still do their job just fine.
