Man i always have problems sigh...
Old Oct 30, 2007 | 06:07 PM
kaonashi's Avatar
First boost creep now these:
P0069 MAF mechanical Fault
P0507 - Idle speed higher/lower then expected < i lowered my idle today after i found out what this code was because i had raised it a bit after the cam install so im sure thats why its throwing that code its sitting at 800 now instead of 1100rpms
P0462 - Fuel level unit sending condition.........
The book said that it ment low circut on the fuel pump ............ wtf i had this lol
Old Oct 30, 2007 | 06:53 PM
Redline-Z's Avatar
Veteran: Air Force
Dang and I am fed up of clearing my P0420 every week. Looks like you need to do some tweeking
Old Oct 30, 2007 | 06:57 PM
sekula's Avatar
Well the whole swap to a 9 probably confused the car a bit...
Old Oct 30, 2007 | 08:14 PM
JDMCT9MR's Avatar
Yeah your swap is kinda the test subject as it does not seem many have performed the swap.Would running a stand alone unit help your car?
Old Oct 31, 2007 | 06:24 AM
kaonashi's Avatar
would probably help most of the codes yes, the Idle is fixed, but the p0069 is from my Maf sensor, and eitherr A its messed up or B the harness is messed up and its glitching so I'll end up needing to geet ride of the maf sensor sooner or later. before it desides to jump into limp mode. and the fuel sending crap i have no idea
The only thing is the car should be freaking out about any of these unless something is actually going out, I changed Everything that needed to be replaced all the sensor etc are brand new. To add i had to solder the maf connections because this harness was cut so that could be my issue as far as the maf sensor goes, And i might have a good idea as to why the fuel sending unit says its low circuit
