YO! CF intake pipes!!
Old Nov 7, 2007 | 11:51 AM
  #31
EVO8emUp's Avatar
I wonder how the tanks are bonded to the core? If anything, I would think the failure would occur there first.
I think it's very innovative. nice work!
Old Nov 7, 2007 | 11:57 AM
  #32
jba3's Avatar
Originally Posted by TempeRacerGuy
Carbon fiber would hold boost no problem. In tube form, the pressure is tensile loaded. In tensile strength, carbon fiber is stronger than steel.
I really like the black intercooler for some reason...
Old Nov 7, 2007 | 11:59 AM
  #33
chu's Avatar
chu
Originally Posted by EvoJoeIX
i think its awesome looking
but how much do you think something like that would be?
Think about how much IC piping is currently, and like triple that amount
Old Nov 7, 2007 | 12:19 PM
  #34
SkylineMyth's Avatar
Originally Posted by Rcebowl
Has anyone seen these?! I'm suppose no anyone else took pictures of this at SEMA...... well anyways Cobb is thinking about making Carbon Fiber intercooler piping and endtanks!! and they are real carbon fiber not just a wrap!.... the sad part.... its for the WRX
Where's the Evo love? hahaha
Whatch ya all think?
It's so sexy, but I'm too poor to put that much money on just the IC and piping
Old Nov 7, 2007 | 12:28 PM
  #35
ray3328's Avatar
it looks amazing, I would take a uicp if it was for a reasonable price
Old Nov 7, 2007 | 12:32 PM
  #36
Peteypab2133's Avatar
I though that CF retains to much heat. Meaning, it would not allow the heat to escape through the UICP when heading to the intake manifold?
  #37
EvoJoeIX's Avatar
http://www.rallysportdirect.com/gall...1/IMG_4901.jpg
in that picture the piping looks welded...
is it just me or what?
Old Nov 7, 2007 | 12:33 PM
  #38
marksae's Avatar
Pretty cool... I wonder why someone hasn't made this sooner..
Old Nov 7, 2007 | 12:53 PM
  #39
KevinD's Avatar
^ cause it will be far more expensive then aluminum or stainless, much harder to work with, higher startup costs, offers no performance gain over steel or Al, you can't just weld a different flange on for a different BOV if you want... basically you'll be paying tons of money to look good i guess there is a market for that though. the weight savings maybe could be justified, but it can't possibly be much less then the aluminum pipes which are pretty light to begin with. for the porsche 944 turbo i remember someone was manufacturing carbon fiber intake manifolds. they were significantly lighter then the stock aluminum one, but they cost 3000 dollars :O.
Old Nov 7, 2007 | 02:39 PM
  #40
RalliArtEvoVIII's Avatar
CF pipes...not too bad...CF IC end tanks=rice/tacky
Old Nov 7, 2007 | 05:12 PM
  #41
Robevo RS's Avatar
i would be affraid to put it on the FMIC... I got dings and dangs all over my FMIC from racing.
I don't know ,how this unit would hold against small rocks etc.
And if you make it too thick ...
but interesting for sure.
Old Nov 7, 2007 | 05:33 PM
  #42
MajorPayne's Avatar
Exactly what I was thinking...unless there is some special bonding process, this wouldnt work much better than plastic end tanks like come on a lot of stock vehicles.
Also to those using the heat transfer properties as justification...why would you want the tubes to be insulated? the air, even moving through Al tubes, is going to be cooled off, thought it may be a tiny bit...if it is insulated in CF tubes...it will be that much LESS cool when it reaches the intake manifold.
But there is an exception to this...and that would be if the intercooler piping was really close to a heat source and the air around it was NOT cooler than the intake charge (to go ahead and mention this...when the car is in motion, the underhood temps will only be a few degrees warmer than the ambient air temp...yet still cooler than intake charge)
So, I suppose it would come down to application, the tubing I can see working in some instances...I'll have to see more data on the intercooler to have an opinion :P
Old Nov 9, 2007 | 09:47 PM
  #43
03SilverEvo87's Avatar
Love it
Old Nov 10, 2007 | 07:36 AM
  #44
TempeRacerGuy's Avatar
OK, the carbon fiber ***** that I am did some research on this. The sleve material is about $36 per yard which isn't that bad. If I had access to an auto-cad system and CNC cutter, molds could be easily made for these.
Anyone in here work for a design/machine shop? If so, you could make a small fortune.
Old Nov 10, 2007 | 08:17 AM
  #45
EvoJoeIX's Avatar
where i work, we make our own carbon fiber...lol
and its not the over-lay junk either, pure CF baby
anyway, how do you connect two peices together? cause you cant bend CF
