Evoscan
Old Nov 24, 2007 | 11:58 AM
destro92179's Avatar
Evoscan
How accurate are the graphs on evoscan??? My knock count seems pretty high...over 20.
Old Nov 24, 2007 | 01:14 PM
gsrboi80's Avatar
Uhh sounds like you need a tune
Old Nov 24, 2007 | 01:22 PM
alan678's Avatar
+1
BTW...make sure you are using the "Knock Sum" (Request ID: 26) to read your knock....
Old Nov 24, 2007 | 03:30 PM
krazirob's Avatar
better add some fuel or cut timing......................................seemed pretty accurate when mine was roadtuned with evoscan
Old Nov 24, 2007 | 03:43 PM
spdracerut's Avatar
Eh? Evoscan reads exactly what the ECU reads. Only place there can be an 'error' is with the sensor.
Old Nov 24, 2007 | 05:07 PM
alan678's Avatar
or if logging the incorrect Knock Request ID....those other options can read other than 0 when the actual knock sum at 0...
Make sure you have the correct option chosen...
Old Nov 24, 2007 | 07:16 PM
Turns out Im runnin a lil lean so getting a fuel pump this week. Also I am currently getting tuned.
Old Nov 25, 2007 | 01:24 AM
evonrp's Avatar
why would you mod without a fuel pump......
