Heat shield
Old Nov 28, 2007 | 09:54 AM
Evo8uk's Avatar
Heat shield
About to fit a 10.5 hotside and titek o2 housing is there any problems not using the lower heat shield as it cant be fitted when using a stainless o2 housing. Also the titek came with a new gasket but im not sure if i should use this or get a O.E gasket.
Old Nov 28, 2007 | 09:59 AM
heyzeus11's Avatar
You should be fine without the lower heat shield.
Old Nov 28, 2007 | 10:04 AM
dancarroll0283's Avatar
I'm fine without the lower on my car, and i always use the OE gaskets, they fit better...
Old Nov 28, 2007 | 10:31 AM
Evo8uk's Avatar
Cheers for the replies Are the metal gaskets generally ok to re-use or would you suggest buying new gaskets before the install?
Old Nov 29, 2007 | 09:21 PM
fishbums's Avatar
If the metal gaskets dont have any physical damage to them, then I usually reuse them and never had any problems
