Headlight replacement question
Old Nov 28, 2007 | 06:21 PM
blueevokev's Avatar
Hey Guys,
I recently found out my left headlight is out (HID Bulb) where do i find a replacement and does anyone have any pricing?? Im not too sure who and where i can buy either a bulb or if its a whole HID unit to replace it. Sorry, im just not too farmiliar with the HID's and was looking for some help. Thanks so much.
Old Nov 28, 2007 | 06:22 PM
sl0ev0's Avatar
having the same exact problem, left hid fading, aftermarket tho. anyone know if bumper removal is necassary?
Old Nov 28, 2007 | 06:49 PM
kilgoja's Avatar
how much is it at the dealer?...just wondering...might need to change mine one day down the road...my first hid car as well
Old Nov 29, 2007 | 03:31 PM
JDMCT9MR's Avatar
Look at the headlight lens.There should be something that says D2S.That should be the type of bulb that EVO's use for the headlight bulb.You can try www.sylvania.com
They should have the type of bulbs the EVO uses listed from the corner light bulbs to the reverse bulbs.
Old Nov 29, 2007 | 04:06 PM
RussellM's Avatar
Plat Vendor
Here is a link with the OE bulb.
http://www.mitsubishiparts.net/cart/?id=571&pn=MU820005
Old Nov 29, 2007 | 04:23 PM
blueevokev's Avatar
Originally Posted by RussellM
and thats the same with the HID bulb? i dont know anything about HID's.
Old Nov 29, 2007 | 08:24 PM
dubbleugly01's Avatar
one of my HID units went bad. It went from a clean blue light and faded to pink before it got dimmer and dimmer. It wasn't the bulb but the HID unit. Luckily I was under warranty. Yes, bumper removal is necessary to access the HID module. But that's the good news, the module itself is over $300 plus labor.
Old Nov 29, 2007 | 08:28 PM
healthynine's Avatar
Any H2S bulb will work...its a standard size HID bulb for a projector lens. You can probably find aftermarket for cheaper assuming the ballast isn't bad.
Old Nov 30, 2007 | 05:12 PM
blueevokev's Avatar
thanks so much guys.
anyone have any detailed instructions on taking it apart and replacing and how much is involved in it? thanks so much for the help
Old Nov 30, 2007 | 06:22 PM
SteelEvo's Avatar
make sure you replace them in pairs..as hids get older they color change..if you only get one new one the colors wont match...you have to take off the bumper..after that its straight foward..well taking out the headlight there should be 3 bolts...mitsubishi engineered these headlights soo retarded
