Installing a VG without the Clip
Old Nov 30, 2007 | 04:27 PM
AmF_15's Avatar
I bought a VG a while ago, I just finished getting it painted to match my tb evo9. I went to the "How to" section on the forum to help me install it, I found out that I am missing the clip that I never got. My question is do I need the clip? Whats the clip for? Thanks
Old Nov 30, 2007 | 07:20 PM
Most-Wanted's Avatar
I know I've been away for awhile, but I don't ever remember any clips. They are held in place by double sided tape(4 pieces). The antenna also is screwed on over it, holding it in place. And the rear window trim goes over top as well holding it in place. So, no clips that I have ever seen. Hope this helps
Old Nov 30, 2007 | 07:32 PM
DJmarkymark's Avatar
never had a clip with mine
Old Nov 30, 2007 | 07:37 PM
kstpeter33's Avatar
no clip with mine either...just 3m tape
Old Nov 30, 2007 | 07:40 PM
lexat20's Avatar
when you say clip are you refering to the ends closest to the doors?
mifesto's Avatar
no clips. double-sided tape to fasten it down. weather stripping helps abit on the side and antenna helps too.
Old Nov 30, 2007 | 09:47 PM
LoCo4's Avatar
You are talking about the clip for the antenna.....don't know if you really need it.
Old Dec 1, 2007 | 06:55 AM
AmF_15's Avatar
That is what im talking about, well if I don't need it then good, i was upset I couldn't put it on.
Old Dec 1, 2007 | 08:52 AM
DSMEVOLUTION's Avatar
The clip for the antenna just holds it down more securely. It uses the antenna to screw down over it and make sure the VG is more snug. I ran my original VG without a clip for a year because I didn't know what it was for or how to put in on. When I replaced it with another VG I used the clip the 2nd time around. It's not something that is needed....
Old Dec 1, 2007 | 11:31 AM
grillpt's Avatar
I have the clip on mine, like DSMEVOLUTION said I think its just to hold it down more securely. Makes it sit a little more flush. You'll be fine w/out it.
Galante
May 25, 2016 01:07 PM
george3
Nov 21, 2015 05:48 AM
shinnster
19
Feb 11, 2010 08:26 PM
EvoRSfor060
Dec 7, 2007 01:37 PM
xanderracing
Sep 26, 2007 11:33 AM
