broken bov?
Old Dec 9, 2007 | 02:02 PM
calilancer02's Avatar
broken bov?
I'm using the stock BOV on 24 psi (i kno im a cheap ***) and lately, I can't boost over 5psi without hearing a mass air leak comming from the car, it also feels like I have a blown coupler when I go above 5psi. I've checked all vaccum lines and couplers upper/lower and inside the engine bay, everything is sealed. I was recently tuned @ 25psi for my setup and haven't had a problem going on 2 months. But when I was driving (radio on so I didn't hear anything pop) I was comming out of a turn and got on it, and it felt like there was no coupler. Couldn't boost over 5psi, steadily. If I floor the damn thing regardless of what happens, the boost creeps up, but car doesn't go anywhere.
Since the stock BOV looks in working condition, but Im no mechanic and can't take it a part and actually know if it is broken, I'd say its safe to assume this is the problem?
Old Dec 9, 2007 | 02:16 PM
MitsuJDM's Avatar
VIII or IX BOV?
Old Dec 9, 2007 | 02:17 PM
IX bov guess i'll list the mods incase it helps anyone, injen intake lower/upper IC pipes, espilier exhaust + testpipe, hallman pro mbc tuned 100oct
It acts exactly as if theres a blown coupler in the way it responds to acceleration. Except, its easy to drive without going over 5 psi, which is unlike a blown coupler. Which leads me to believe the BOV is bad.
Old Dec 9, 2007 | 02:24 PM
Redline-Z's Avatar
Veteran: Air Force
Boost leak tester with soapy water and you will find it. A good freind of mine had all kinds of problems with his Injen pipes, I would check them first.
Old Dec 9, 2007 | 02:27 PM
prostcj's Avatar
Sounds like a boost leak from piping.
Old Dec 9, 2007 | 02:30 PM
will boost leak test it 2nite then, ima head to the store and buy me a homemade one, and i'll double check all the injen piping again, especially around bov
Old Dec 9, 2007 | 02:37 PM
prostcj's Avatar
Check where the piping connects to the fuel intake. I had problems there for a while.
Old Dec 9, 2007 | 02:45 PM
Redline-Z's Avatar
Veteran: Air Force
If you are running the stock clamps go ahead and ditch them for T clamps, if not use a 10mm socket on them and not a screwdriver and coat the sealing surface with hairspray.
Old Dec 9, 2007 | 03:00 PM
thanks for all the advice guys, i'll go back out and double check everything, cuz we all know evo isnt an evo w/o boost :X
Old Dec 9, 2007 | 03:06 PM
MitsuJDM's Avatar
Hairspray works great. I kept blowing the throttle body coupler on my Mirage. Used some hairspray and double clamped it. Hasn't blown since
Old Dec 9, 2007 | 08:07 PM
epson1's Avatar
+2 for hair spray
