Next Step
Old Dec 11, 2007 | 07:17 AM
K1lla Haz3's Avatar
Next Step
I have a Evo IX SE and i have some mods to it and just want your guy;s oppinion on what i should do next.
current Mods:
-HKS Racing Suction Intake
-HKS Hi-Power 3" Cat-Back Exhaust
-Hallman Pro RX Boost Controller Kit
-Walbro 255 Fuel Pump
-TURBO XS 3" DOWNPIPE/TEST PIPE
-costum Tune
I m looking at about 400 to 500 hp, and i am currently at 334 whp. i am open for any suggestions on what to do next
Old Dec 11, 2007 | 07:26 AM
Evo007's Avatar
Meth injection and cams can get you around 400whp. with intercooler upgrade and piping upgrade.
Old Dec 11, 2007 | 07:27 AM
MREvolution06's Avatar
It going to depend on what you want to do with your car. If your looking to get into that hp range you might want to upgrade your turbo. I would also suggest upgrading your fuel pump if you haven't already. If anything upgrade your fuel pump and piping first, then worry about your turbo, cams, meth, ect.
Old Dec 11, 2007 | 07:47 AM
XK120's Avatar
--Intercooler w/ proper piping
--Meth (I wouldn't unless you go top of the line kit i.e. Aquamist)
--Cams (not producing the kind of numbers they did on 8s since the stock 9 cams are very well desgined
--Turbo. Many options here, but if you want to keep stock like spool and not have to do other major upgrades go with an FPgreen
Old Dec 11, 2007 | 09:04 AM
Well spoken!!
Old Dec 11, 2007 | 09:59 AM
K1lla Haz3's Avatar
they all sound like good i deas thanks guys.. i already have a fuel pump, i was thinking about getten the HKS 272 cams, i have a stock BOV and i dont know if i should change it.
Old Dec 11, 2007 | 10:03 AM
Evo007's Avatar
If you go meth and turn up the boost you are going to need an aftermarket bov.
Old Dec 11, 2007 | 10:06 AM
XK120's Avatar
The stock IX DV should be fine
K1lla Haz3's Avatar
my boost is set at 22 right now u think i need a bov or am i fine for the mean time?
Old Dec 11, 2007 | 10:07 AM
You don't need to change it out, unless you want the whossh sound. If that's the case I recommend a dual port one. APS, Turbosmart, Go fast bits all make nice dual port BOV's. I'm selling my dual port if you want it. It's a Turbosmart. Honestly I would wait for the cams and open her up more. Change the piping. ETS offers a great kit for a great price.
Old Dec 11, 2007 | 10:08 AM
XK120's Avatar
YOU ARE FINE WITH THE STOCKER
Old Dec 11, 2007 | 10:11 AM
I know of guys using the stocker push over 25psi. Your good!
Old Dec 11, 2007 | 10:20 AM
CrackerJackToy's Avatar
Meth, Cams, FMIC, Piping and your right around 400-410whp. Evo green will put you up too 430+ish whp. GT30R setup will put you around 425on 93 octane, and around 485-500 on race gas or meth injection. GT30R setup will spool a little later than the stocker, but around 3800-4200.
Old Dec 11, 2007 | 10:50 AM
Wicked White's Avatar
Well, if you don't already have a twin disk clutch, that would be next for sure. You can't regularly push 400 to 500 horsepower through a stocker or something similar. Then if you want a true boost in power, look at upgrading your turbo setup. At this point, don't waste your money on minimalist upgrades, just go for a larger turbo. I think buschur has the best setups.
Old Dec 11, 2007 | 11:32 AM
XK120's Avatar
Why not spend the money on supporting mods? Better build up well then just go straight for the turbo kit.
