Boost Leak Test
Old Dec 11, 2007 | 08:25 AM
yikez's Avatar
Boost Leak Test
Long story short, i suspect i have a big boost leak somewhere. Made my own boost leak tester and connected it to the intake pipe (only removed the cone filter - 'aftermarket intake').
Found a small leak, fixed it. Still feel there is a leak somewhere that the boost leak tester is not detecting. Question is, is the boost leak test only done on the intake pipe area? 99% of boost leak tests i've saw in the forum start at the intake pipe area. HOWEVER, i saw one person doing a boost leak test from the throttle body hose. Either attaching the tester to the throttle body itself, or the TB hose.
Is this a way of finding other boost leaks? If so should i connect it to the throttle body itself or the TB hose?
I've searched and i know how to make a boost leak test and all, just surprised at the thread i read ..
thanks
Old Dec 11, 2007 | 08:27 AM
TeStUdO's Avatar
You did the test correctly. Why do you feel you still have a leak?
Old Dec 11, 2007 | 08:36 AM
yikez's Avatar
Hey man .. im still running in circles with my problem (pop, sputter sounds). I've narrowed it down to a few things im going to try out tomorrow if u see my original thread.
Testudo, will a boost leak test show leaks after the turbo e.g. 02 housing.
Old Dec 11, 2007 | 08:40 AM
yikez's Avatar
This is the read that talks about doing a boost leak test somewhere from the throttlebody ..
https://www.evolutionm.net/forums/sh...d.php?t=312581
Old Dec 11, 2007 | 08:41 AM
TeStUdO's Avatar
I responded to your original thread. I doubt you have the throttle body seal leak. It wouldnt suddenly pop up and cause the problem you are having.
Old Dec 11, 2007 | 08:52 AM
yikez's Avatar
I've read that you can have leaks from the injector (not the injector itself but the housing or the rubber around it).
And since i changed my injectors, i may have damaged them somehow..
