Type RS Adjustment
Old Dec 20, 2007 | 07:40 AM
EgoBstr's Avatar
Type RS Adjustment
Put a GReddy Type RS on last night with recirculation (I know I took off the JDM that comes on the IX) and it seemed to work fine regardless of where I set the adjustment screw. How do I know if I am getting surge? From the factory it comes on the softest setting. Do I leave the screw at the softest setting, or how do I adjust it to work properly?
Save your its a waste of money comments.
Old Dec 20, 2007 | 07:44 AM
KillaItalian904's Avatar
do you have the high boost spring in it. i adjust mine as tight as possible without fluttering under my max boost.
Old Dec 20, 2007 | 08:10 AM
EgoBstr's Avatar
I have not idea what spring is in it.
OK so what I should do to adjust it is continue to turn it toward hard until it flutters under max boost and then turn it back a little?
Old Dec 20, 2007 | 08:14 AM
mifesto's Avatar
i would start about full tight, then loosen about 4 full turns out. and go quarter turn up or down until flutter is in acceptable frequency. dont want too loose or too tight.
Old Dec 20, 2007 | 08:28 AM
EgoBstr's Avatar
What is considered acceptable frequency? Full boost without any flutter? Right now I get flutterwhen I let off at small amounts of boost. I have no idea what to listen for and when.
Old Dec 20, 2007 | 08:33 AM
you dont want it to flutter when under full boost i would tighten it up alot and loosten it until it stop fluttering under your full boost, the flutter is fine when your under low boost
