SRS recorder connectors help.
Old Dec 21, 2007 | 03:32 PM
mr2driver's Avatar
Can someone help me out here. My SRS recorder connectors where disconnected and I cant tell which one plugs in where. Both plugs look exactly the same except for the wire placement.
If you pull out your ashtray you will see it down there on the floor, 2 yellow plugs with yellow wire loom covers. One of the plugs has most of the wires towards the middle of the plug and the other one has about 3 or 4 on the bottom row. Can someone check this out and let me know which is plugged where? It is very easy to see. A picture would be even better! TIA
You can disconnect one at a time to see what the wire placement looks like. Just make sure your battery is not connected when doing so.
This is an EVO 9 if that matters.
Old Jan 15, 2008 | 03:49 PM
mr2driver's Avatar
Anyone? There aren't any EVO owners living near me that I know of.
