Evo Won't Start
Old Dec 26, 2007 | 07:42 AM
Crz10's Avatar
Evo Won't Start
Well christmas day i was at my mother house 1HR alway. My sister ask me to take her to the store. so i did well at the end of the night getting everthing to gether to go home my car wouldn't start it cranks but it won't turn over. if anybody ever had this problem HELP ME !!! it is getting gas i can mile it when i crank it.
Old Dec 26, 2007 | 07:46 AM
staatz's Avatar
Battery dead? Got a small battery? Mine died a few times. A good push n pop startin' it fixed that prob..haha Goodluck.
Old Dec 26, 2007 | 07:49 AM
Evoryder's Avatar
did you try jumping it?
Old Dec 26, 2007 | 10:56 AM
Crz10's Avatar
Battery is good it gives me a go crank
Old Dec 26, 2007 | 11:10 AM
[Neo]'s Avatar
That still might be the problem- get the battery checked at Pepboys-if its still good check your ignition fuse. I had the same problem it would crank but not turn. I took it to the dealer and they replaced the $2 fuse and charged me $96. Wasnt covered because of my Turbo Timer.
Save yourself the time & money! Hope this helps
Old Dec 26, 2007 | 11:24 AM
Crz10's Avatar
Thank you i will check that
Old Dec 26, 2007 | 11:51 AM
Crz10's Avatar
Is there anyway you can send me a pic showing me were that ignition fuse is at. just want to make sure i don't miss anything before i take it to the shop.
Old Dec 26, 2007 | 11:54 AM
Turbolover's Avatar
Try a battery charger.
Old Dec 26, 2007 | 05:44 PM
Slomo Corey's Avatar
Triple check all your fuses.
Old Dec 26, 2007 | 07:01 PM
eclipsegsx012's Avatar
lately i have seen alot of battery problem. If i were you i would check CCA on your battery just be on safe side because my car and my friends car had this problem.
Old Dec 30, 2007 | 04:42 PM
Crz10's Avatar
I found the problem with my evo it was a ignition fuse and AC fuse inside the car
i burned a 10 amp and a 7.5 amp fuse. I replaced them and car turn on with no problem. Thank you guys for all the help
