JDM Climate Control For USDM Evo
Old Dec 28, 2007 | 11:51 AM
redleg225's Avatar
I did a bit of searching but couldn't really find this out, maybe someone can help. Does anyone know the cost and difficulty of putting the JDM climate control in a USDM Evo. In case anyone doesn't know what I'm talking about, it looks like this:
Attached Thumbnails JDM Climate Control For USDM Evo-mitsubishi_lancer_evo_ix_wagon_2005_04.jpg
Last edited by redleg225; Dec 28, 2007 at 11:52 AM. Reason: Changed link to attachment
Old Dec 28, 2007 | 11:52 AM
chaotichoax's Avatar
difficulty = high
cost = high
why?
jdm climate controls are not mechanical like ours
Old Dec 28, 2007 | 11:54 AM
redleg225's Avatar
Why? Something different, and it looks better. As for cost, define high. I'm a baller. And as for difficulty, explain. Otherwise I think you don't know what you're talking about.
Old Dec 28, 2007 | 11:56 AM
OldschoolEVO's Avatar
so far you don't know what your talking about
the entire system is motorized. if you want to be different get a Bimmer
Old Dec 28, 2007 | 12:06 PM
badstainless's Avatar
If you "baller" couldn't you just buy a JDM Evo?
Old Dec 28, 2007 | 12:08 PM
06MRV8Killer's Avatar
Good point
Old Dec 28, 2007 | 12:32 PM
SlowSportSedan's Avatar
you might have money... but you wouldnt buy a pos evo and want climate control.. you buy it to race cause its cheap and fast
any1 who considers themself a baller is a fool, and should put down the crack pipe....
this is a baller
Old Dec 28, 2007 | 12:34 PM
racerxl99's Avatar
ur a tool
Old Dec 28, 2007 | 12:37 PM
tripperfx3's Avatar
Its going to be hard and expensive because as mentioned the USDM's Evo AC/heater controls are all mechanical (cable driven/moved) while the JDM is electrical (probably sends a signal to the ECU or the system has its own ECU and is then changed by a motor of some sort). So it would be hard and expensive to source out the parts from Japan as that is where you would have to get them all Im sure.
So what you need to do is make friends with a Japanese auto tech (i believe all auto techs in Japan have to have a 4 year degree in mechanical engineering, so anyone will do). Have him buy the parts and then have him fly out and install it for you. There you go baller!
Old Dec 28, 2007 | 12:41 PM
twentyone's Avatar
Alright balla, here's a quote from Rich@Orbital who replied about this in another thread.
Originally Posted by Rich@Orbital
those controls are electronic, our controls are manual.
if you expect a conversion like that to work you better be prepared to spend easily over $1000.. and that is a conservative guess.
you'll need the unit itself, various temperature-sensing themostats & actuators, wire harnesses, most likely a different HVAC compressor, an OEM radio relocation kit, JDM wiring diagram, USDM wiring diagram, and of course a highly-specialized/experienced installer to handle the absolute nightmare of a splicing/custom-wiring job that this is going to take.
oh, and you'll also need an OEM mitsubishi 2-DIN bezel with or without and optional OEM mitsubishi 2-DIN overlay.
Old Dec 28, 2007 | 12:47 PM
TheDriver11421's Avatar
once again.. this is ballin:
http://youtube.com/watch?v=GzFqLjJLGUM
never gets old
Old Dec 28, 2007 | 01:00 PM
andyktlee's Avatar
Pocket Mo
I guess that's the TS ballin'. Ballin' into a nice fail.
Old Dec 28, 2007 | 03:42 PM
JDMCT9MR's Avatar
Getting the JDM climate control is not worth it like all others have stated on this thread.Why not get some JDM MR headlights if you want some JDM goodness.
Old Dec 28, 2007 | 03:53 PM
t51splbb's Avatar
I think you mistook what chaotichoax meant when he said "why?". He was just explaining why both the cost and the ease of installaltion was so. Instead you took it as a opportunity to be rude .
Old Dec 28, 2007 | 03:58 PM
JDMCT9MR's Avatar
+1.Looks like he doesn't know what he is talking about.
