help motor bog?
help motor bog?
hey guys just recently when i hit the gas in my car it bogs then spools up. its the weridest thing???...i have no idea wat it is....if im in 3rd or 4th gear say at 3500rpms and punch it to take off it will bog down rele low then take off.....its not turbo lag either i no what that is...its not a slipping clutch since im not even on the clutch....idk what it is..,,couple ppl told me it was the stock boost controller??
i have no ideaaa
please help
i have no ideaaa
please help
do your pm shoot up?
you being on the clutch has nothing to do with your clutch slipping
a clutch slips when you gun it in a higher gear and the rpm jump without the speedo in sync
no no no i do hit fuel cut but not until higher rpm!...the boggging is happednig at low rpm in a gear...ill hit the gas and it bogs then feels like it takes off....clutch slip?...
keep in mind i do hit fuel cut at high rpms and it did hit "over boost"
please help!!!
please help!!!
mine does similar to that, now im saving to get a clutch. Advice start saving and buy a good clutch. it will get worse as it goes on and at 3500rpm i think is pretty bad. take it easy on the take off and "punching it"
Sounds like a fuel delivery issue. Or your ECU is running off safe mode from 'over boosting'? Do you have a guage to measure what PSI it's peaking at? Using the right octane? Does it stumble on a quick rev in neutral or only when it's in motion?
$1500 dollars later ha
Not tryin to hijack, but yesterday car ran great, this morning, go to leave for work, and it is bogging or missing only down low. Once i get to a sweet spot, the car lunges forward and takes off like a bat outta hell. I will check it out better when i get home. I just find it hard to believe that the clutch can do that overnight?! And if it was the clutch, my car probably wouldnt suddenly lunge forward and take off....it would probably slip right? I have an Exedy twin just waiting for the weather to break, but just figured i would see what people said here.
