Humidity Problem
Old Jan 9, 2008 | 08:14 AM
BocaShula's Avatar
Humidity Problem
Ok let me start off by saying that i've searched and searched and found nothing on this topic. My car has a problem or something... the carpets are always wet when i get in the car. I've tried everything with the AC system... I need help.
Old Jan 9, 2008 | 08:45 AM
rjdevo9_mr's Avatar
my wife's car is exactly the same, but she has a ragtop z3 and we traced it to a leaking roof
Old Jan 9, 2008 | 08:59 AM
nirvancol's Avatar
I have read about a few other people having this problem. I believe it was caused by a bad grommet in one of the front wheel wells. Search around for that
Either that or maybe something related to the HVAC system
Old Jan 9, 2008 | 09:03 AM
nirvancol's Avatar
i found a few topics that could be the same problem that you are having:
https://www.evolutionm.net/forums/se...archid=7142069
Old Jan 9, 2008 | 09:06 AM
Flipbboy03's Avatar
+1 on this one.
Old Jan 9, 2008 | 10:32 PM
BocaShula's Avatar
thanks for the help fellas
Old Jan 10, 2008 | 03:17 AM
PHDoc19's Avatar
How often do you notice this (meaning "always" is a subjective term)? Are you currently running your AC? Wet or dry conditions outside? Does your neighbor have a sprinkler system?
Old Jan 10, 2008 | 03:24 AM
spdrcr456's Avatar
do u have a sun roof?
Old Jan 10, 2008 | 05:56 AM
nothere's Avatar
if the grommet /cap on the narrow band o2 sensor is not installed your floor will fill up with water too.
kept thinking I had a little bit of water in the car until I looked under the carpet.
just look at the underbody on the passenger side next to the cat. where the cat wires go into the body, make sure the cap is attached.
Old Jan 10, 2008 | 02:49 PM
BocaShula's Avatar
No my neighboor does not have a sprinkler system and no im not running the A/C. This usually happens during and after rain or when its real humid out. It's leaving a terrible smell in the car...
Old Jan 10, 2008 | 02:50 PM
BocaShula's Avatar
No, no sunroof.
Old Jan 10, 2008 | 02:53 PM
BocaShula's Avatar
You're talking about underneath the car right...?
Old Jan 10, 2008 | 05:15 PM
nothere's Avatar
yes, for some reason a significant amount of water comes into the car up through that hole.
Old Jan 10, 2008 | 05:34 PM
EJEvo's Avatar
There was a TSB about early '03 Evos leaking at some grommet and causing problems with the ECU. They used to have this info listed at CNN Autos, but I can't find it now.
Old Jan 10, 2008 | 11:34 PM
heavens turbo's Avatar
quit messing with the a/c, cause it is obviously a leak if it happens after rain! you're carpet is starting to get sour cause a carpet can hold alot of water. at the shop i work at, we remove the carpet and put it under a heat source. (like a heater.) sometimes that doesn't work. first, remove the interior at the affected area or the whole interior and dry it as best as possible. you'll have to determine if the leak is coming from the front or rear and watertest the affected area with a garden hose or rainmaker. eventually water will seep in and viola! sometimes it's a ***** trying to get a leak to show up. good luck!
