Most usefull gauges?
Old Jan 21, 2008 | 06:05 PM
Aux.'s Avatar
Boost and the AEM UEGO...can't go wrong.
Old Jan 22, 2008 | 09:17 AM
GSXRolla's Avatar
The boost is a must. After that, wideband, or EGT. You'll want to know what's going on inside that engine of yours.
Old Jan 22, 2008 | 10:38 AM
travman's Avatar
Originally Posted by racer135
I will be installing only two gauges on my evo. One of them will be boost and I am still debating what would be the best choice for the second gauge. My car will only have TBE, MBC (22 psi on 93 octane), Walbro, Filter, LICP and Tune. Which gauge will give the most usefull information?
Just get a boost gauge (need it to dial in the mbc properly) and a LC-1 (wideband) and log it through evoscan, no need for a gauge because 20 bucks after a good pull someone asks you what your afr was you will say I dunno? because you weren't staring at the wideband gauge driving at x speed.
But logging it allows you to go back after a pull and go ahh thats what my afr was...
And unless your racing it constantly...you don't really need any other gauges unless you like having a light up show across your dash.
Old Jan 22, 2008 | 10:39 AM
travman's Avatar
Thats why you log.....knock sum is more important than egt
Old Mar 20, 2008 | 12:06 AM
casual's Avatar
im in the same situation. im looking to get the defi imperial 60mm boost and oil press. but not sure what my third should be. either water temp or fuel press. what do you guys think?
Old Mar 20, 2008 | 05:30 AM
philevo's Avatar
Wideband
Old Mar 20, 2008 | 05:46 AM
EvoDom's Avatar
Wideband
Old Mar 20, 2008 | 06:06 AM
beastlytalon's Avatar
Originally Posted by brian250f
6" tach with a 50 watt red shift light (minimum 10 hp gain) everyone above pretty much summed it up...
That is a must for coolness.
Old Mar 20, 2008 | 06:09 AM
phabaznbro's Avatar
I'm not so sure that wideband gauge itself is that terribly useful...as someone mentioned above you won't be looking at that while driving all too much. You just really need the functionality for logging. Other than that I'd say boost, egt, oil pressure, fuel pressure...
Old Mar 20, 2008 | 07:21 AM
Guz Man's Avatar
oil temp, oil pressure, and if you have room for a 3rd gauge, get an AFR...
those are life savers... for me at least
Old Mar 20, 2008 | 07:54 AM
krazirob's Avatar
wideband helps a lot especially when you start modding some more
Old Mar 20, 2008 | 08:46 AM
JKD's Avatar
JKD
I have...
1. Boost
2. Oil Pressure
3. EGT
I don't have a wideband yet, but I plan on getting one very soon. IMO, a wideband is one of the most important you can get.
Old Mar 20, 2008 | 10:27 AM
1320 Engineering's Avatar
I have AEM wideband and prosport boost, oil pressure and egt.
not only are the prosports useful, theyre pretty too
Old Mar 20, 2008 | 11:00 AM
CharlieGsanD's Avatar
Boost, EGT, Wideband AFR
Old Mar 20, 2008 | 11:58 AM
Draven83's Avatar
i have boost, oil press, wideband
