****Need assistance****
Old Jan 21, 2008 | 08:16 PM
MREvolution06's Avatar
Alright here is my problem. While driving around @ like 25 mph my car will start to sputter and some time even act as if I was a brand new driver learning the clutch. You know how the car shakes roughly when your about to stall it out? Anyways I don't know how to put it into words that would describe it to a tee. I'm thinking it has to do with my MAF but I'm not too sure. Has this happened to anyone else? Any feed back would be helpful.
Another thing I'm experiencing is when I come to a stop and throw in the clutch, my idel will drop, shoot up, drop again, then even out. I do have 272's in and know that it should have a crazy lope, but this is like my idel is bouncing. Any thoughts?
Thanks in advance!
Old Jan 21, 2008 | 08:19 PM
34Turbo's Avatar
Are you running your bov vta? It could also be a bad boost leak problem...
Old Jan 21, 2008 | 08:22 PM
ImJoey's Avatar
I experience this as well.Only in first gear light throttle.Same cams,crazy idle unless a/c is on, ses light comes on at idle every other week, etc. I cant wait until I can get a reflash and solve all this.
Old Jan 21, 2008 | 08:24 PM
No, I'm still running stock MR DV. I also boost leak tested and found nothing.
Old Jan 21, 2008 | 08:30 PM
KenMasters's Avatar
Fouled plug or bad ignition coil?
Old Jan 21, 2008 | 09:09 PM
RussellM's Avatar
Plat Vendor
The symptom sounds like a MAF Sensor to me, but the specific speed makes me lean away from it.
