Rear Shock Bolt!!! Help Me!!!
Old Jan 29, 2008 | 09:26 AM
bboy_RES's Avatar
how many lbs of torque do you guys think i need to break this bolt loose? i can get 250 lbs for $10 and 400 lbs for $40. which one should i get?
Old Jan 29, 2008 | 09:38 AM
tweakdsm's Avatar
make sure you get/buy PB Blaster, spray it wait 5min and give it a try, you do not need an impact wrench, and make sure your lift (rear) both sides (it makes easier to take the bolts out and put the back on, if you're not using lift. I always use 17mm wrench on one end and 17mm socket on the other. Goodluck
Old Jan 29, 2008 | 09:51 AM
bboy_RES's Avatar
yeah i used tons of pb blaster on it and it still wont budge. i got the bolt off on the rear left shock, but it took some time. the bolt on the rear right shock is giving me a harder time because it's starting to strip. the impact wrench will make things a lot easier.
