Tranny Problems on Cold Days
Old Jan 31, 2008 | 10:07 AM
  #31
EVOJR$'s Avatar
normal. 3rd is the easiest to shift into first. what i do is double clutch while parked and put it in 3rd. then 4th then 5th. than go through neutral and into reverse. it always works. i think that loosens everything up because after doing that, it goes into everything perfectly fine.
Old Jan 31, 2008 | 10:12 AM
  #32
92gsxbaltimore's Avatar
that is normal. you want to manually rev match your syncros. Its called double clutching.
Old Jan 31, 2008 | 10:19 AM
  #33
90GSX-03EVO's Avatar
What? Double clutching is called double clutching. Rev matching is called rev matching.
