New Problem...Need your help
Old Feb 19, 2008 | 08:56 AM
4cdndctn's Avatar
Originally Posted by NYEvoguy
confirmed same size tires and wheels.
Good - you have 2 options for your next step.
Drain and fill with fresh fluid or simply fill up. I would drain and refill and allow any metal to drain with the fluid.
I run about .6qts Motul Competition ff in my rear diff and have had no problems - It's expensive for a fluid but cheap for an insurance policy
Everyone has their $.02 on diff fluid - there is plenty of opinions to find in searching.
If the problem persists after that, I would try to best isolate the problem so you don't spend uneccesary dollars.
Old Feb 19, 2008 | 11:36 AM
NYEvoguy's Avatar
Well VIP is saying that my T-case was leaking fluid bad but i never noticed anything. they drained and refilled all the fluids and said that its better but he wants to run it again and check it out again to see for anything else. I just don't understand how the T-case would cause the rear diff to lock up.
Old Feb 20, 2008 | 05:40 AM
NYEvoguy's Avatar
waiting on results.
Old Feb 20, 2008 | 08:34 AM
NYEvoguy's Avatar
no call yet. i have a bad feeling that this is going to cost me an arm and a leg.
Old Feb 24, 2008 | 09:12 AM
steevo 8's Avatar
looks like your heading straight to what im going to. i had whines while only in gear and rolling in gear, got a new tranny, tcase started to whine... got a new tcase now theres a little leak from the tcase and dont understand it. just about had enough of it and might think about getting rid of it
