odometer problems is final step..HELP!
Old Feb 19, 2008 | 10:10 PM
wicked06Mr's Avatar
my friend just finshed rebuilding his wrecked evo 9...all is good but the problem is that the odometer is not working, its not moving at all, could there be a fuse blown(he checked everyone) or maybe a broken plug somwhere? need help asap, this is the only thing holding him back from his inspection, thanks
Old Feb 19, 2008 | 11:34 PM
waynea's Avatar
If the speedometer works and the odometer doesn't, it sounds like a problem in the electronics of the gauge assembly. To the best of my knowledge the odometer is just an electronic integration of the speed and I think that is done in an integrated circuit on the gauge assembly, but it may be done in another circuit board. Can he get or borrow a used/working gauge assembly?
Old Feb 20, 2008 | 07:51 AM
wicked06Mr's Avatar
no, neither one work....
Old Feb 20, 2008 | 07:54 AM
avengerhed's Avatar
i know this seems elementary, but is the speed sensor connected in the transmission? maybe is missing or broken?
Old Feb 20, 2008 | 08:28 AM
wicked06Mr's Avatar
i know...but where would we even begin lookin for a plug?
Old Feb 20, 2008 | 08:51 AM
avengerhed's Avatar
i believe it's right on the transmission bell housing.
if no one else chimes in, i can send you some info from my factory service manual when i get home tonite...i'll be able to tell you exactly where it is...
Old Feb 20, 2008 | 09:05 AM
TouringBubble's Avatar
I'm pretty sure it's right on top of the bell housing as well ... it's fairly obvious as I remember, but I might be recalling the transmission area without the battery try installed.
Old Feb 20, 2008 | 09:59 PM
waynea's Avatar
The diagram is not very good, but it appears that the sensor is on the top back corner of the transmission near the transaxle. I doubt it is near the bell housing as I expect it to be connected to the output shaft.
