Fluids change
Old Feb 27, 2008 | 06:02 AM
AKgambler47's Avatar
Fluids change
I am getting my oil changed, what other things should i have changed? I dont go to mitsu, I am at 18100 miles and i havnt had all my fluids changed for about 10000 miles. Oil i get about every 3000 miles. And can you reccomend the fluid i should use and where to get it(autozone,walmart, places like that). I use mobil one for oil, so i dont need advice for that.
Old Feb 27, 2008 | 06:09 AM
6-speed's Avatar
You should definetly change your transmission, transfer case, and rear differential fluids.
Transmission: OEM, Redline MT-90, or Penzoil Synchromesh
Transfer Case: OEM Diaqueen LSD Gear Oil
Rear Diff: Same as above
All the other fluids just check to see if you're at a good level like the ACD & coolant.
Honestly, it's not too hard to change any of the fluids, especially the transmission.
Good luck.
Old Feb 27, 2008 | 06:32 AM
Alright, cool, thanks
