Take a look at my DataLogLab Dynos
This is on my new 3065 setup. This is no tuning whatsoever, 23psi, all mods in sig. We havent even began tuning at all, and have atleast 15 more pulls to get it all dialed in, so dont bash the numbers, this isnt what its about anyway. *Read on*.
No tuning at all, no knock at all, 10.0 afr to redline.
What I dont get, is I revved out to 7625rpm on this map, and it shows I let out, at like 6600 according to this DLL. Why does it do that? Does that technically mean im making more power than its showing? (10.8 AFR at redline)
Its not that it really matters since im using DLL for comparing my before and after, but I was just curious if that was an error within the program and if anyone else had experienced this.
You need to adjust the range used for the dyno graph. I usually set the range using my TPS (start when 100% throttle starts and end where the throttle closes). If you use too many points after the throttle closes it drops off the way yours do.
-Paul
-Paul
