Cam Discussion
Old Mar 3, 2008 | 12:09 PM
turbo271's Avatar
Cam Discussion
For someone who doesn't want to do internal work and wants a great amount of added power from cams, which set would be the best choice?
Remember - No internal work! Just cams.
What do you guys recommend?
Old Mar 3, 2008 | 12:11 PM
TeStUdO's Avatar
Remember - This topic is covered 10 times a week. Try searching or post on the Newbie forums.
Old Mar 4, 2008 | 11:02 AM
justin44's Avatar
Search for HKS cams.
Old Mar 4, 2008 | 11:04 AM
Burklow's Avatar
Doesn't matter what set of cams...at minimum you'll need to bleed the lifters. Does that count as internal work?
Old Mar 4, 2008 | 05:26 PM
evoPirate's Avatar
probably get more response in a more appropriate forum. go down to the turbo/power forum, its discussed in 4-5 new threads per day.
BUT, quick overview - HKS popular, no springs/work needed for 264, 272 or 280 (expensive for the gains) Brian Crower no work needed 264/272, fairly popular and cheap. Comp cams no work needed for 264 (maybe 272), not as popular, still fairly cheap. Cosworth 264/272, no work, popular, expensive. GSC S1 no work needed, very popular, similar price to HKS. JUN's - forget em, expensive and requires work. Tomei - see JUN. Buschur Racing BF customs - see JUN. I'm sure there are more, but those are the most commonly discussed
Old Mar 4, 2008 | 10:10 PM
personal_golf's Avatar
Veteran: Air Force
I got HKS cams with alcohol and tuned by Sean Ivey. It's a beast for "stock". Good luck!
Old Mar 4, 2008 | 10:56 PM
Crazy K's Avatar
I wouldn't say bleeding the lifters is internal work, jus somethin you should do so you don't bend a valve or somethin, I got Brian Crower stage 2 or 272's, haven't installed them yet but you get a pair for a great price
