*** How often do you change your spark plugs?? ***
Old Mar 25, 2008 | 08:04 AM
cheb evo's Avatar
Originally Posted by ribbie78
Just put coppers in last oil change so probably again soon...
Sekula (or anyone with the copper NGK's): what gap are you using?
Been using .026 on mine.
Old Mar 25, 2008 | 12:53 PM
daved's Avatar
i got about 36,ooo miles and haven't changed them yet.
Old Mar 25, 2008 | 12:57 PM
dsmfan95's Avatar
I change mine about every two oil changes.
Old Mar 25, 2008 | 01:04 PM
Dero's Avatar
I'm at 40,000 on the stock plugs. I pulled them not too long ago and they looked perfect.
Old Mar 25, 2008 | 01:09 PM
SICK SPEED's Avatar
18K and still on the stock plugs.
Old Mar 25, 2008 | 01:35 PM
4cdndctn's Avatar
Originally Posted by sekula
I use NGK coppers so I change them every oil change, which is every 5k miles since I use amsoil. evo 8 btw
Same here as far as intervals - .26 gap and 0 knock count
Old Mar 25, 2008 | 02:17 PM
Evoz's Avatar
Got 30k on mine about to have them changed out this service, im mostly stock though.
Old Mar 25, 2008 | 03:00 PM
sekula's Avatar
Mine are gapped at .024 since I run 30 psi sometimes on race gas, and don't want to change the gap from .026ish to .024 everytime I up the boost, so I just leave it at .024.
Old Mar 25, 2008 | 03:12 PM
06MRV8Killer's Avatar
cheapest place to buy stock plugs anyone?
Old Mar 25, 2008 | 03:16 PM
grillpt's Avatar
I went to 45K, I believe the manual calls for it at 60K. They were fine, could have done another 15K.
Iridium is one of the hardest elements on earth, that ish can take a ton of heat and abuse.
Old Mar 25, 2008 | 04:10 PM
EvoooB's Avatar
i usually do them every 15k and use the 1 step colder NGK's. havent had a problem yet
Old Mar 25, 2008 | 05:05 PM
hk2ronin's Avatar
the same but evry 2,500-3,000 miles...use Mobil1 oil. Can't beat $1.87 a piece for plugs.
Old Mar 25, 2008 | 05:45 PM
1d10t's Avatar
When ever they need to be changed!!!
Old Mar 25, 2008 | 06:04 PM
Curt@MrLed's Avatar
Former Vendor
ngk br7es
Old Mar 25, 2008 | 06:13 PM
ImJoey's Avatar
-Every 3k with oil change. BPR7es gapped to .026
-$8 for plugs and whole process takes 15 minutes.
-I dont do my own oil changes so I have to comphensate by doing plugs
