drawing a blank. maybe its a brain fart
Old Mar 29, 2008 | 06:15 PM
TEAM ACE's Avatar
in the sentence " put a tee fitting in the dv line" for a boost gauge. what the hell is the dv line????
Old Mar 29, 2008 | 06:18 PM
EJEvo's Avatar
Dump valve, diverter valve, or as some refer to it, the blow-off valve. HTH.
Old Mar 29, 2008 | 06:22 PM
TEAM ACE's Avatar
duh thank you def a brain fart
im trying to figure out why i cant control my boost.
mbc hold 15 to 5500 then creeps to 20, then just keeps going.
i cant seem to keep it low enough to get to redline without overboosting
Old Mar 29, 2008 | 07:34 PM
Burklow's Avatar
What if: instead of tapping the DV line for an MBC, use the turbo nipple for boost source? IMO, it is the best method.
Old Mar 29, 2008 | 08:13 PM
W_evo8's Avatar
^ thats what I did, works great.
Old Mar 29, 2008 | 09:01 PM
sparky's Avatar
Are you installing a boost gauge? If so, then you should "T" into the fuel pressure regulator line. Or, are you doing an MBC install? If the later is the case, then you should "T" into either the line that runs between the diverter valve and the intake manifold, or else connect to the nipple on the compressor housing discharge tube.
Old Mar 29, 2008 | 09:16 PM
TEAM ACE's Avatar
i have the gauge and mbc hooked up fine i just cant seem to get to redline without over boosting. any ideas would be greatly appreciated.
Old Mar 29, 2008 | 09:21 PM
Burklow's Avatar
Which install method did you use for the MBC?
Old Mar 29, 2008 | 09:34 PM
TEAM ACE's Avatar
removed line from hot side to wastegate. capped the hotside. then ran line from wastegate to a tee in the blow off line with the mbc in the middle. . . . . .now the flow should be coming from the intake dowm to the wastegate.
fugiwara
Jun 1, 2016 02:13 AM
roidz3
Nov 3, 2015 08:15 AM
taylorgang
Nov 23, 2011 08:19 PM
inco9nito99
Mar 8, 2010 11:19 AM
ksattic
Apr 2, 2008 01:36 PM
