Clutch question....?
Old May 13, 2008 | 02:47 PM
vmrevo9's Avatar
Veteran: Air Force
well it's only noticeable when i'm pulling out of my garage since every noise is somewhat amplied. it doesnt make noise while driving or shifting into gears.
Old May 13, 2008 | 03:46 PM
Evo9tunerz's Avatar
Get the ACT, it's the best clutch under 500 bucks. For the flywheel, just go and resurface your stocker. The stocker weighs around 14 lbs and there is no point of buying a 12 lb. for 200 when you can resuface for 30 dollars.
Old May 13, 2008 | 03:51 PM
KiiD2X's Avatar
How do you guys tell?
Hey, I got a IX MR all stock with about 5500 Miles on it i had it for about a year now. I think its time for a new clutch but im not sure. My rpm keeps going down and up constantly and its not turbo lag.
How do you guys know if its time for a new clutch before your car breaks down in West Bumble****?
Old May 13, 2008 | 05:02 PM
Jeff_Jeske's Avatar
^Get the car rolling at 25mph in 3rd gear then mash the pedal to the floor.... if RPMs climb but the car doesn't go anywhere then its slipping.
Old May 13, 2008 | 07:13 PM
vmrevo9's Avatar
Veteran: Air Force
i keep on hearing different weights for the stock flywheel. last i heard it was 16lbs. so is it really 14 pounds?
Old May 14, 2008 | 02:27 PM
KiiD2X's Avatar
Thanks alot my friend.
I think its time for a new clutch than....The Exedy Organic Clutch should do just fine right? (Im planning on getting the AMS Stage 1-3 Kits)
Old May 14, 2008 | 03:24 PM
Jeff_Jeske's Avatar
I've heard nothing but bad things about the exedy stg 1 organic disk.
Old May 14, 2008 | 05:15 PM
vmrevo9's Avatar
Veteran: Air Force
yeah the exedy stage 1 is not meant for anything over stock power. they dont last long and i had pm a reputable shop and they said they would not recommend it. go with the ACT HDSS
