Which wideband to get... AEM or Zeitronix Zt-2 ??
Old Apr 11, 2008 | 04:57 AM
racer135's Avatar
The AEM UEGO has an RS232 outout and an analog 0-5V output for data logging. You can use hte RS232 to log with EVOScan using a serial cable to the PC and the USB Tactrix Cable to log with EVOScan with the OBD2. It logs but you need a PC connected to log the data and two cables (Tactrix and Serial). The 0-5 is for non stock EMS systems.
Old Apr 11, 2008 | 05:10 AM
DR EVO_38's Avatar
I would also recommend the Innovate
Old Apr 11, 2008 | 06:12 AM
tony_b's Avatar
They just did a comparison of a whole bunch of WB's not that long ago.
Zeitronix hung with WB's costing 4x as much. I believe the AEM didn't rate so high because of inconsistent readings...
Old Apr 11, 2008 | 07:31 AM
lemmonhead's Avatar
AEM Uego you can log using stock ecu and evoscan. there is a thread on where to attach the serial output wire to the rs232 connector to your computer.
works great
Old Apr 11, 2008 | 07:33 AM
lemmonhead's Avatar
actually yoru wrong, i saw that test and AEM was mostly ontop 1-2 on every test.
i will have to try to find that thread and post it.
Old Apr 14, 2008 | 05:25 PM
Shocky's Avatar
I use AEM and I love it, and would recommend it any day!
Old Apr 14, 2008 | 06:32 PM
tony_b's Avatar
http://www.fordmuscle.com/archives/2...tout/index.php
Old Apr 14, 2008 | 07:56 PM
Sluggo's Avatar
(Air-Fuel Meter Shootout continued.)
Requires Subscription
Old Apr 14, 2008 | 08:04 PM
tony_b's Avatar
well.... subscribe!
edit: even better, read this thread: https://www.evolutionm.net/forums/sh...d.php?t=325408
This was the one I was actually talking about earlier. When I searched the first time, I saw the pipe with all the bungs and thought that was the one. I was wrong. This was the one.
Old Apr 14, 2008 | 08:05 PM
sidtheretard's Avatar
aem
Old Apr 14, 2008 | 08:07 PM
Evoryder's Avatar
zt2...easy installation, software is caveman easy to use, analog outputs, failsafe triggers for meth addicts like myself...great product.
Old Apr 14, 2008 | 08:10 PM
90GSX-03EVO's Avatar
ZT-2, all the way. It's so simple to install / use / log with it.
Old Apr 14, 2008 | 08:11 PM
Hikaru's Avatar
Originally Posted by CanMan
Ooh, Innovate is VERY good. I would suggest that! I know I just said that I have AEM, but in all honesty, when I bought mine, my buddy had the AEM in stock, so I just went with that. I probably should have gone with the Innovate, but the AEM has been great. I am happy with the AEM.
luv yer quote man. I forgot bout that movie...makes me laugh everytime...
Old Jan 20, 2013 | 01:38 PM
17579EVO9MR's Avatar
To bring this back from the dead. I have the aem wideband with my ems 2. I used to have the zt-2 in my car before i went to the aem standalone. I have the gruppe s triple pod with the aem wideband,boost and oil pressure. I've come to the conclussion im going to take the aem gauges out and go with the zt-2 again. I love he fact that you dont have to watching the gauge all the time. The zeitronix has a peak button, that tells you your peak afr, and boost and such for your previous run, or pull. Personally if you have a high powered car, you can't always be taking your eyes off the road to look at a gauge. Thats 3/4 the reason I'm putting th ezt-2 back in.
Old Jan 20, 2013 | 04:57 PM
slimjim1804's Avatar
I've had UEGOs in my last two cars, so I'm a little bias, and I've never seen the zt-2 in person. However I can say multiple AEM users have reported issues with them reading lean. Mine was a bit different than my tuners readings on the dyno, FWIW
Posted from Evolutionm.net App for Android
