cheap place for fluids
Old Apr 29, 2008 | 09:21 PM
JDMCT9MR's Avatar
^Your welcome.
Old May 21, 2008 | 08:16 AM
porsherules911's Avatar
Just did all 3 fluids with the oem stuff (Diaqueen 75W85 tranny fluid, LSD SAE90 Gear Oil). Running this gear oil for the tc and the rear diff in a Mr is fine right? Only reason i ask is because on lancershop they have the LSD Gear Oil I used and a MR Super Multi Gear Oil. I guess I'm just being paranoid... I'm hoping its fine i used the regular oil and not the super multi gear oil.
Old May 21, 2008 | 08:38 AM
bbyevo8u's Avatar
what fluid does it say to use in the manual!? thats the fluid you should have used if it is then your fine.
Old May 21, 2008 | 08:39 AM
bbyevo8u's Avatar
what kind of fluid pump do you have and were do you get it?
Old May 21, 2008 | 08:51 AM
i got mine at autozone worked fine.
Old May 21, 2008 | 08:59 AM
PHDoc19's Avatar
off topic: how hard is it to change tc, rear diff, trans fluids? i've never done it before but i do no how to change my oil. i ask because i am goiing to have to change those fluids very soon and i dont know if i should go to the dealer or do it myself if its not to hard would someone chime in and let me no sry for hi jacking the thread
John
If you can do an oil change, you can do this. Putting the fluids back in is a little trickier, but not hard. Some people use fluid pumps, but they really aren't necessary and can make a mess if you try to go too fast. Good ol' gravity works just as well.
http://evomoto.com/tech_info.php?tPa...e7e950693d95fa
Rear diff is even easier.
Old May 21, 2008 | 09:44 AM
all it says in the manual is use 75W85 for tranny fluid and just LSD for the tc and rear diff. Guess it doesnt make a difference if its the regular or the super multi oil.
Old May 21, 2008 | 09:50 AM
bbyevo8u's Avatar
were can i get (GL-5) diaQueen super multi gear oil 75W-85 for my 6 speed? and limited slip differential oil (LSD)?.....mitsubishiparts.net and evomoto.com does not have it so were can i buy these fluids
Old May 21, 2008 | 09:55 AM
are u sure you searched? Try here: http://www.mitsubishiparts.net/catal...ction=575#1348
Old May 21, 2008 | 10:04 AM
lords3t's Avatar
RussellM at Mitsubishiparts.net has the oil for the 6-speed tranny. I should know, he's my sole OEM parts/fluid provider
Old May 21, 2008 | 11:35 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
how much do you think mitsu would charge if i had them replace tc, rear diff and trans fluid?
I know you aren't in CA, but I was quoted by San Rafael Mitsubishi:
Rear Diff: $50
Transfer Case: $38
Transmission: $86
So about $175.
Old May 21, 2008 | 05:51 PM
bbyevo8u's Avatar
yeah it says Diaqueen 75W85 Manual Transmission! but it does not specify that its SUPER MULTI GEAR OIL (GL-4)?
Old May 21, 2008 | 05:53 PM
06MRV8Killer's Avatar
the title of your thread is totally setting you up for OT comments
Old May 21, 2008 | 06:50 PM
holler mcdollar's Avatar
Originally Posted by stikillller
anyone else??????
if you feel like just picking some stuff up... extremepsi.com's warehouse is in bensalem... not sure where in the city you live but i'm in the northeast and they're a 10 minute drive from me. i go over there for all my oem fluid/filter/whatever needs.
not sure of the prices off hand, you can check their site. in my case convenience > price though plus i'd rather support local guys.
Old May 21, 2008 | 06:51 PM
wickdaddy's Avatar
not OEM, but PM Oil Doc for pricing on the Amsoil fluids
