mods power and time for evo
Old Aug 9, 2003 | 09:39 PM
evoinit's Avatar
i am wondering what is the bst way to go to mod my evo
what are your mods and what times are you runnin and if you have a dyno sheet whats your power
Old Aug 10, 2003 | 01:24 PM
evo1's Avatar
Re: mods power and time for evo
Try doing a search ...
However, it is common to assume that an ECU mod (leaner map), 3" turbo back exhaust (or at least 2.5" on the downpipe), and boost that does not taper much on its way to redline typically puts down 270-290 whp on a dyno. I believe that catless evo's, or one's that are capable of running higher boost than stock (i.e. 20-21 psi) are at the higher end of this assumption.
