Help, car wont start
Old May 13, 2008 | 08:29 PM
jojo3620's Avatar
so my car was in storage all winter and i had it on a charge holder...i took it out a few weeks ago and it started right up. pulled it in the garage and it sat for about another week before i took it out for a spin...had to use a jump box to start it. a week later and it wont start again. so i pull out the jump box and nothing. turn the key and the lights come on and everything, but car wont start. doesnt make a sound when i turn the key to turn it on, no clicking or anything. what could this be? any help is appreciated!
Old May 13, 2008 | 08:38 PM
recompile's Avatar
Is the booster pack dead?
I imagine if you had to boost it a week ago and it worked without a problem, and now it doesn't, that it's the same problem...
Do you have an alarm and/or lo-jack ?
Old May 14, 2008 | 04:28 AM
jojo3620's Avatar
i have an alarm. i plugged the booster pack in over night to charge it and will give it another go. i'll update later and let you know
Old May 14, 2008 | 05:32 AM
recompile's Avatar
The booster pack shouldn't be used to charge the battery... you should just hook it up and try starting it right away.
Old May 14, 2008 | 07:29 PM
jojo3620's Avatar
i know that.. i meant i have the charger plugged into the wall...when its fully charged i'll hook it up to the battery and try starting it then
Old May 14, 2008 | 07:30 PM
hanahawaiian's Avatar
maybe ur fuel stale... or check all coils n Spark plugs make sure all is good.. and keep try starting ur car..
Old May 14, 2008 | 10:04 PM
Bom's Evo's Avatar
Is it the original stock battery? might not hold a charge anymore. It's kinda old now. I just changed mines this winter. It lasted a good 5 years.
Old May 16, 2008 | 07:11 AM
jojo3620's Avatar
gas should be good, and its the buschur mini battery, i'll have to check the plugs
Old May 18, 2008 | 01:08 PM
jojo3620's Avatar
took the jump box off the charger this morning, slapped it on the battery and after a second or two, car started...i guess the battery must have been completely drained. thanx for the help guys!
