HOw to tap power from fusebox
Old Aug 12, 2003 | 04:18 PM
NRG's Avatar
NRG
Hey guys, I am trying to install my boost gauge and I need 12v source to light my gauges up. I heard people have used the fusebox to get that source. My question is, what kind of connector do I need to crimp onto the wire to tap onto the fuse. I believe its the fuse for the interior instrument gauges.
Thanks advance!!
Old Sep 15, 2003 | 03:27 PM
EVOXTC's Avatar
I want to know this as well....like HOW to go about it not just "you have to tap it from the fuses..." cause that doesnt help me much...anyone able to help?
-J
Old Sep 15, 2003 | 03:31 PM
Coolguy949's Avatar
unless you want your backlight on all the time, you should find a switched power source that activates when the headlights are on. Either the fuse box or the ECU will have this.
Old Sep 15, 2003 | 03:37 PM
nastea's Avatar
radioshack sells fuse taps, both full size and mini..
Old Sep 15, 2003 | 04:42 PM
berkel's Avatar
Hey guys,
I tapped a line in the fusebox under the steering wheel. You should get the fuse thingies from radioshack to do it right, but what I did was strip some wire, wrap it around the fuse, and put the fuse back in. You wrap enough around the fuse so it wedges itself in there, but I was careful so it doesn't have bare wire moving around, in case it shorts or something.
You can use the gauge cluster or something similar so the gauge lights up when your lights are on.
Good luck,
FB
Old Sep 15, 2003 | 04:47 PM
freedom's Avatar
Re: HOw to tap power from fusebox
Thanks advance!!
Do a search on the howto forum for DEI alarm install. There are instructions which define where accessory power can be found, as well as the required connector. Given that the output is fused in the box, a secondary fuse is redundent as it would be inches from the real fuse.
Walmart sells a 3m connector (tap) which is ideal for this application. The tap presents a spade lug connection for the attaching wire.
Old Sep 15, 2003 | 04:52 PM
wmcorcor's Avatar
Be awre that even the mini-fuse taps from radio shack would not fit in for me.
Old Sep 15, 2003 | 05:26 PM
weightless's Avatar
I went to 3 different radio shacks and they didn't have mini-fuse taps available, just the regular sized ones. You need something like this:
http://www.tjtrailers.com/store/wirt...usetapper.html
Its gonna be a tight fit, you have to use force to plug it in.
tiesto14
Aug 9, 2016 05:20 PM
joon82
Jun 3, 2009 02:56 PM
Spooky_Neo
Jun 24, 2008 02:04 PM
Iamkar33m
50
May 23, 2003 02:02 PM
