help with boost taper...
Old May 31, 2008 | 01:31 PM
EVOIXMR8916's Avatar
ams replaced my hotside and exhaust manifold....thats the only time its been touched outside of me...
Old May 31, 2008 | 01:50 PM
bump....help me please
Old May 31, 2008 | 01:56 PM
Rnm's Avatar
Rnm
Evo9's taper more so than the 8's.
Old May 31, 2008 | 02:20 PM
yea, but its not normal to taper from 24psi to 12psi...
Thanks,
-Dan
Old May 31, 2008 | 02:31 PM
EvoBroMA's Avatar
do you have a downpipe? i have a stock catback, and it holds 19psi at red line. i will be adjusting my wg to see if it helps up top.
Old May 31, 2008 | 02:47 PM
i have stock downpipe....u think thats it????
Old May 31, 2008 | 03:20 PM
1d10t's Avatar
Boost pill removed?
Old May 31, 2008 | 03:26 PM
Evoryder's Avatar
12psi drop is excessive. That's actually lower than standard was gate...i believe it should be a min of 14psi. It might be your wastegate opening early and dumping boost. Might be a good time for a forge 9 wg. check your bov to.
Old May 31, 2008 | 03:29 PM
1d10t's Avatar
^+1 Wastegate and bov. You can get an 18 psi gate for around $100
Old May 31, 2008 | 03:30 PM
fugiwara's Avatar
why?
Old May 31, 2008 | 03:32 PM
fugiwara's Avatar
why did you replace your hotside already?
call AMS since they are the one work on your car
Old May 31, 2008 | 03:34 PM
dsmfan95's Avatar
Are you still on the stock intake? Do you hear a hissing noise?
Old May 31, 2008 | 06:20 PM
yea im on stock intake, and when it drops to 11psi i hear a hissing noise like real clearly....
Old May 31, 2008 | 11:48 PM
Chamama's Avatar
Is your intake snorkel firmly held down by the clips? If not, then there is a problem.
Old Jun 1, 2008 | 12:53 AM
what intake snorkel???
