Hooking up a boost gague
Old Jun 8, 2008 | 08:15 AM
Inflation's Avatar
Okay so I have my MBC hooked up and I'm now on my boost gague. The gauge came with a barbed T to hook it up to the lines. Do I hook it up to the hose from the Wastegate or Turbo?
If neither where do I hook it up.
Thanks in advance!
Old Jun 8, 2008 | 08:18 AM
Psquared's Avatar
There are several places people may suggest. If you look at the left side of your intake manifold (psgr side) there are 2 small black hoses. The stock MR gauge pack is tapped into one of those. If you need a pic, I can go snap a quick one...
Old Jun 8, 2008 | 08:21 AM
Inflation's Avatar
If you wouldn't mind that would be appreciated
Old Jun 8, 2008 | 08:23 AM
Psquared's Avatar
ok...gimme a sec. I gotta run out to the garage...it's super easy I promise. The biggest pita is running the hose through the firewall....make sure you use a grommet, or another piece of hose so it doesn't get a cut/slice in it....be right back..
Old Jun 8, 2008 | 08:24 AM
Thegame's Avatar
http://evomoto.com/tech_info.php?tPa...325a429189e405
Check out step 3
Old Jun 8, 2008 | 08:26 AM
Psquared's Avatar
^^work smarter not harder....thanks......hey I'm from the "burgh"!...damn pens...
Old Jun 8, 2008 | 08:31 AM
Inflation's Avatar
Haha Thank you both very much! I found what you 2 were talking about. My gague came with this clear housing much smaller then the vaccum hosing. Do I even need that or do I just get new vaccum hosing. I'm using an auto meeter gague
Old Jun 8, 2008 | 08:45 AM
Psquared's Avatar
As in, it's an additional hose to a boost/vacuum hose the gauge already came with? I'm thinking it's the one they supplied to hook up to your car.
Old Jun 8, 2008 | 08:46 AM
Inflation's Avatar
YES! its working. Thanks! Now I just have to figure out how to work the MBC
Old Jun 8, 2008 | 08:51 AM
Psquared's Avatar
Start off with the mbc all the way "unscrewed". Least ammount of boost. You will probably still boost 12lbs. That's wastegate pressure. Then in controlled increments, like 3 or 4 turns at a time. Up the boost to your prior settings.
Old Jun 8, 2008 | 09:01 AM
importjake00's Avatar
Good help guys! Glad its working for you!
