Mitsubishi Refuses to Repair My Car - HELP!
Old Jun 11, 2008 | 11:25 AM
  #46
JDMevoBOOST's Avatar
I have only heard of one case where someone used that to get their warranty off of "blacklisted" status and I am sure it was a pain.
Old Jun 11, 2008 | 12:46 PM
  #47
Last4G63's Avatar
Originally Posted by dafarmer69
It may be your input shaft bearing. I am noticing lot of people are getting confused between this and the deathwhine. Not saying its your problem, but I have a bad input shaft bearing. It sounds the same as a t/c. The only way to tell the difference is, you can hear the i/s bearing whining slightly when not moving with the clutch out. When the clutch pedal is pushed in it goes away. T/c wont whine if the car isnt moving.
Just my thoughts for ya since I cant actually here the car.
Good thought, I was thinking the exact same thing because the noise began to occur after the rebuilt my transmission under warranty. The transmission was replaced after that (they thought it was the input shaft as well), but it did not solve the issue.
Old Jun 11, 2008 | 08:11 PM
  #48
hytek369's Avatar
hope this clears up.
Old Jun 11, 2008 | 08:19 PM
  #49
rickay726's Avatar
id be so mad man good luck
Old Jun 12, 2008 | 06:33 AM
  #50
evoego's Avatar
Registered User
Originally Posted by Last4G63
I will be loyal no more, once it is fixed, it's being sold.
thats exactly what I did brother!!
Old Jun 12, 2008 | 06:38 AM
  #51
evoego's Avatar
Registered User
Originally Posted by Brian_H
I'm well aware of what it is, I've heard it mentioned thousands of times on here and many other automotive forums over the past few years by people who got their law degrees at Phoenix Online. One thing I've never seen is someone that's been able to use it to their advantage. It didn't benefit stew in a similar situation where his motor had grenaded. Have you seen an instance where its worked? I haven't.
wrong...my motor grenaded twice...fixed twice!! second time whole new one...Mitsu agreed to giveme a whole new car, but then decided they had done enough and would just replace motor since car was modded.......then I got the hell outta Mitsu's BS and Evo SOLD!! I sure do miss my BEAST tho.....
Old Jun 12, 2008 | 06:45 AM
  #52
4g63smokinall4s's Avatar
Originally Posted by JDMevoBOOST
Here's a tip....if they fix ur car three times for the same part that means you can lemon law it. If you lemon law it the dealer is screwed, so they told you that its normal so they dont have to fix it the third time. I would contact a lawyer to at least write you up a letter saying that if they plan on not warrantying an obvious issue because they are afraid of the lemon law then that is going to get them a lawsuit. They'll change their tune.
Brilliant!
Old Jun 12, 2008 | 07:00 AM
  #53
Brian's Avatar
OK, one good account noted.
Old Jun 12, 2008 | 07:27 AM
  #54
Methodical4u's Avatar
just curious... have you emailed Mitsubishi directly?
Old Jun 12, 2008 | 09:08 AM
  #55
rdandy5875's Avatar
lucky for you that now they've fixed it 3 times. If the noise persists you have a good Lemon Law case.
Old Jun 12, 2008 | 09:10 AM
  #56
BocaShula's Avatar
lime law
Old Jun 12, 2008 | 09:29 AM
  #57
Thomar's Avatar
keep us up to date on this... im curious
Old Jun 12, 2008 | 10:10 AM
  #58
S4STIEVO's Avatar
This Is Not A Lemon Law Issue Theyve Never Fixed The Problem.
Old Jun 12, 2008 | 10:18 AM
  #59
EvilToaster101's Avatar
Hope this gets figured out, wish you the best of luck with the arbitration thing. I havent purchased my evo yet and it is making me have 2nd thoughts :\
Old Jun 12, 2008 | 10:35 AM
  #60
Last4G63's Avatar
I haven't because the dealership has been attempting to fix it. I wanted to give them a chance, but now I have a couple of options.
A) I claim Lemon Law. However, I have concerns that this is NOT a quick process and I am not sure what I would get for my car.
B) Have independent mechanics diagnose the problems (verifying it is the transfer case) and bring it to Mitsubishi via arbitration in hopes that they fix it.
