where is ACD pump located?
Old Jun 21, 2008 | 10:23 AM
ym3n3's Avatar
does anyone know wheres the ACD pump located? is it in the front where the engine bay is or is it in the rear where the backseats are? thanks
one more question do you know where can i get acd fluids? its kinda low thanks guys
Old Jun 21, 2008 | 10:30 AM
Mitsutech56's Avatar
Directly below the driver side headlight behind the bumper.
It uses Mitsubishi SP-III ATF to activate the ACD.
It may look low but to check the fluid level you have to use the MUT-III scan tool.
Last edited by Mitsutech56; Jun 21, 2008 at 10:32 AM. Reason: Added info for fluid level checking
Old Jun 21, 2008 | 10:47 AM
gbmoto313's Avatar
if its low you might want to get your tc checked because their is the acd oil and rear diff oil in the tc and if the seal between them is broken and fluids are exchanging you could have problems
